Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel 9a Wide Camera Replacement
Ce dont vous avez besoin
    1. Google Pixel 9a Wide Camera Replacement, Safety precautions: étape 1, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Safety precautions: étape 1, image 2 de 2
      • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables and completely power down your phone.
      Demander à FixBot
      Ajouter un commentaire
    1. Google Pixel 9a Wide Camera Replacement, Remove the SIM card tray: étape 2, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the SIM card tray: étape 2, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the SIM card tray: étape 2, image 3 de 3
      • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of your phone until the tray ejects.
      • A small mic hole is next to the SIM tray—don't confuse the two!
      • Remove the SIM card tray.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Heat the rear cover: étape 3, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Heat the rear cover: étape 3, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Heat the rear cover: étape 3, image 3 de 3
      • Adhesive secures the rear cover to the frame. Heating the cover softens the adhesive, making it easier to separate.
      • Use a hair dryer to heat the entire rear cover.
      • Only heat your phone so it's just hot to the touch. Extreme heat can damage the rear cover, screen, or battery.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement, Apply a suction handle: étape 4, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Apply a suction handle: étape 4, image 2 de 2
      • Apply a suction handle near the center of the rear cover's right edge, as close to the edge as possible.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Insert an opening pick: étape 5, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Insert an opening pick: étape 5, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Insert an opening pick: étape 5, image 3 de 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
      • Insert the tip of an opening pick into the gap.
      Demander à FixBot
    4. Google Pixel 9a Wide Camera Replacement, Adhesive information: étape 6, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Adhesive information: étape 6, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Adhesive information: étape 6, image 3 de 3
      • The rear cover is secured with adhesive around the perimeter of the frame and near the cameras. Use this picture as a reference while you separate the adhesive.
      • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and its graphite film.
      Demander à FixBot
    5. Google Pixel 9a Wide Camera Replacement, Separate the rear cover adhesive: étape 7, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Separate the rear cover adhesive: étape 7, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Separate the rear cover adhesive: étape 7, image 3 de 3
      • If you ever have trouble separating the adhesive, apply more heat and try again.
      • Slide the opening pick up the right edge, around the top right corner, and along the top edge to separate the adhesive securing the rear cover.
      Demander à FixBot
    6. Google Pixel 9a Wide Camera Replacement: étape 8, image 1 de 3 Google Pixel 9a Wide Camera Replacement: étape 8, image 2 de 3 Google Pixel 9a Wide Camera Replacement: étape 8, image 3 de 3
      • Insert an opening pick in the initial gap you created near the center of the rear cover's right edge.
      • Slide the opening pick down the right edge, along the bottom edge, and up the left edge to separate the adhesive securing the cover.
      Demander à FixBot
    7. Google Pixel 9a Wide Camera Replacement, Separate the camera bezel adhesive: étape 9, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Separate the camera bezel adhesive: étape 9, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Separate the camera bezel adhesive: étape 9, image 3 de 3
      • Insert the flat edge of an opening pick under the top of the rear cover's left edge, near the camera bezel.
      • Twist the pick and apply constant pressure to separate the adhesive around the camera bezel.
      Demander à FixBot
    8. Google Pixel 9a Wide Camera Replacement, Remove the rear cover: étape 10, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the rear cover: étape 10, image 2 de 2
      • Remove the rear cover.
      • If you feel resistance, go back around the perimeter of the cover and use a pick to separate any remaining adhesive.
      Demander à FixBot
    9. Google Pixel 9a Wide Camera Replacement, Remove the camera bezel: étape 11, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the camera bezel: étape 11, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the camera bezel: étape 11, image 3 de 3
      • If the camera bezel detached from the rear cover and stayed stuck to your phone, follow this step to remove it. Otherwise, skip this step.
      • Slide an opening pick under the camera bezel and pry up to remove it.
      • Only insert the pick a few millimeters under the bezel, or you risk damaging the cameras.
      • If you're having trouble, lightly heat the camera bezel.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the wireless charging assembly screws: étape 12, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the wireless charging assembly screws: étape 12, image 2 de 2
      Outil utilisé dans cette étape :
      Magnetic Project Mat
      $19.95
      • Use a Torx Plus 3IP screwdriver to remove the 16 screws securing the wireless charging assembly:
      • Thirteen 5.0 mm‑long screws
      • Three 2.2 mm‑long screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement, Unclip the wireless charging assembly: étape 13, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Unclip the wireless charging assembly: étape 13, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Unclip the wireless charging assembly: étape 13, image 3 de 3
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Remove the wireless charging assembly: étape 14, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the wireless charging assembly: étape 14, image 2 de 2
      • Remove the wireless charging assembly.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the connector cover screw: étape 15, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the connector cover screw: étape 15, image 2 de 2
      • Be careful not to damage the battery with your tools while disconnecting it.
      • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the battery connector cover.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement, Remove the battery connector cover: étape 16, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the battery connector cover: étape 16, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the battery connector cover: étape 16, image 3 de 3
      • Use tweezers to lift and remove the battery connector cover.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Disconnect the battery: étape 17, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Disconnect the battery: étape 17, image 2 de 2
      • Use a spudger to pry up and disconnect the battery cable press connector.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the logic board screws: étape 18, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the logic board screws: étape 18, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the logic board screws: étape 18, image 3 de 3
      • Use a 3IP Torx Plus screwdriver to remove the two 2.8 mm‑long screws securing the logic board.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement, Lift the logic board: étape 19, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Lift the logic board: étape 19, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Lift the logic board: étape 19, image 3 de 3
      • Be careful not to smudge the cameras when handling the logic board.
      • Before trying to remove the logic board, double‑check that you removed the SIM card tray.
      • Insert the point of a spudger under the screw hole near the cameras and lift the board until you can grip it with your fingers.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Free the bottom edge of the logic board: étape 20, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Free the bottom edge of the logic board: étape 20, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Free the bottom edge of the logic board: étape 20, image 3 de 3
      • Don't try to fully remove the logic board yet, as it's still connected to the frame by the screen cable.
      • Grip the skinny section of the board with your fingers and lift until the clip near the bottom edge of the battery releases.
      • Pull the top edge of the board to the right of the frame until the charge port slides fully out of its recess.
      Demander à FixBot
    4. Google Pixel 9a Wide Camera Replacement, Lay the logic board down: étape 21, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Lay the logic board down: étape 21, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Lay the logic board down: étape 21, image 3 de 3
      • The logic board may fall out of place during this step. Hold it steady, but don't grip any of the camera lenses or connectors.
      • Apply a suction handle to the screen and use it to prop up your phone.
      • Gently lay the logic board down flat against your work surface, being careful not to strain the screen cable.
      Demander à FixBot
    5. Google Pixel 9a Wide Camera Replacement, Remove the logic board connector cover: étape 22, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the logic board connector cover: étape 22, image 2 de 2
      • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the screen cable cover.
      Demander à FixBot
    6. Google Pixel 9a Wide Camera Replacement, Remove the connector cover: étape 23, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the connector cover: étape 23, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the connector cover: étape 23, image 3 de 3
      • Use tweezers to lift and remove the screen cable cover.
      Demander à FixBot
    7. Google Pixel 9a Wide Camera Replacement, Disconnect the logic board: étape 24, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Disconnect the logic board: étape 24, image 2 de 2
      • Use the flat end of a spudger to pry up and disconnect the screen cable press connector.
      Demander à FixBot
    8. Google Pixel 9a Wide Camera Replacement, Remove the logic board: étape 25, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the logic board: étape 25, image 2 de 2
      • Slide the logic board away from the frame and remove it.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the wide camera: étape 26, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the wide camera: étape 26, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the wide camera: étape 26, image 3 de 3
      • Hold the logic board slightly above your work surface while working on the camera—don't press the board against your work surface, or you may damage fragile components.
      • Use the flat end of a spudger to pry up and disconnect the wide camera press connector.
      • Be careful not to damage the four spring contacts next to the connector.
      • Remove the wide camera.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Install the wide camera: étape 27, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Install the wide camera: étape 27, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Install the wide camera: étape 27, image 3 de 3
      • Leave any lens caps or liners on the camera for now—they'll protect the lens during reassembly. You'll remove them before installing the back cover.
      • Put the wide camera into place on the logic board, being careful not to smudge the lens.
      • Align the press connector over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Check the thermal pads: étape 28, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Check the thermal pads: étape 28, image 2 de 2
      • Check the condition of the logic board thermal pads—they'll either be on the bottom of the board or stuck to the corresponding spot on the frame.
      • If the pads are ripped, torn, or otherwise damaged, follow the next five steps to replace them. If they aren't, skip ahead five steps.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement, Remove the thermal pads: étape 29, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the thermal pads: étape 29, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the thermal pads: étape 29, image 3 de 3
      • Use the flat end of a spudger to scrape up and remove the damaged thermal pads.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement: étape 30, image 1 de 1
      • Use high‑concentration (>90%) isopropyl alcohol and a coffee filter to clean up and remove any residue where the thermal pads were.
      Demander à FixBot
    4. Google Pixel 9a Wide Camera Replacement, Apply the thermal pads: étape 31, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Apply the thermal pads: étape 31, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Apply the thermal pads: étape 31, image 3 de 3
      • The thermal pads are very delicate and can easily be misaligned when placing them and removing liners. Take your time when applying them—good placement will ensure proper heat dissipation.
      • Remove the textured liner from the smaller thermal pad.
      • Carefully place the pad onto the board.
      • Use this photo as a reference to help align the pad.
      • Use the flat end of a spudger or your finger to press down lightly on the entire surface of the thermal pad, securing it in place without deforming it.
      Demander à FixBot
    5. Google Pixel 9a Wide Camera Replacement: étape 32, image 1 de 2 Google Pixel 9a Wide Camera Replacement: étape 32, image 2 de 2
      • Slowly lift and remove the remaining liners from the top of the thermal pad.
      • If the thermal pad start to lift up with the liners, lay it back down and press again to secure it.
      Demander à FixBot
    6. Google Pixel 9a Wide Camera Replacement: étape 33, image 1 de 3 Google Pixel 9a Wide Camera Replacement: étape 33, image 2 de 3 Google Pixel 9a Wide Camera Replacement: étape 33, image 3 de 3
      • Repeat the previous two steps to apply the remaining, larger thermal pad.
      Demander à FixBot
    7. Google Pixel 9a Wide Camera Replacement, Slide the logic board into place: étape 34, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Slide the logic board into place: étape 34, image 2 de 2
      • If it isn't already, prop your phone up with the suction handle.
      • Slide the logic board up against the frame so the screen cable is near its connector.
      Demander à FixBot
    8. Google Pixel 9a Wide Camera Replacement, Connect the screen cable: étape 35, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Connect the screen cable: étape 35, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Connect the screen cable: étape 35, image 3 de 3
      • Align the screen cable press connector over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place.
      Demander à FixBot
    9. Google Pixel 9a Wide Camera Replacement, Install the screen cable cover: étape 36, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Install the screen cable cover: étape 36, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Install the screen cable cover: étape 36, image 3 de 3
      • Use tweezers to hook the bottom edge of the screen cable cover into place, then lay the cover down flat.
      Demander à FixBot
    10. Google Pixel 9a Wide Camera Replacement: étape 37, image 1 de 2 Google Pixel 9a Wide Camera Replacement: étape 37, image 2 de 2
      • Use a 3IP Torx Plus screwdriver to install the 1.7 mm‑long screw securing the screen cable cover.
      Demander à FixBot
    11. Google Pixel 9a Wide Camera Replacement, Flip up the logic board: étape 38, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Flip up the logic board: étape 38, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Flip up the logic board: étape 38, image 3 de 3
      • Flip the logic board up so it's gently resting in its recess in the frame.
      • Remove the suction cup and lay your phone screen-side down.
      Demander à FixBot
    12. Google Pixel 9a Wide Camera Replacement, Put the logic board into place: étape 39, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Put the logic board into place: étape 39, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Put the logic board into place: étape 39, image 3 de 3
      • When inserting the logic board, make sure the battery cable doesn't get caught underneath. You may need to gently bend it out of the way.
      • Push the logic board toward the bottom of the frame and press the charging port down until it snaps into its cutout.
      • Press down on the center of the logic board's bottom edge until the clip near the battery engages.
      Demander à FixBot
    13. Google Pixel 9a Wide Camera Replacement: étape 40, image 1 de 1
      • Push down on the top edge of the logic board so it goes into its recess. Make sure the cameras are sitting flush and not at odd angles.
      Demander à FixBot
    14. Google Pixel 9a Wide Camera Replacement, Install the logic board screws: étape 41, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Install the logic board screws: étape 41, image 2 de 2
      • Use a 3IP Torx Plus screwdriver to install the two 2.8 mm‑long screws securing the logic board.
      • Make sure the logic board lays flat, with nothing caught underneath, before tightening these screws.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the old adhesive: étape 42, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the old adhesive: étape 42, image 2 de 2
      • Use a spudger to scrape up and remove the six small pieces of adhesive around the rear cameras.
      • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any residue from the adhesives that were removed.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 43, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 43, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 43, image 3 de 3
      • Remove the larger, clear liner from the inner housing adhesive and lay it in place around the camera holes.
      • Use the cutouts for the small silver pads to help align the adhesive.
      • Use the flat end of a spudger to firmly push down on each piece of adhesive, securing them in place.
      • Remove the colored liner using the pull tab on the top edge.
      • If the adhesive starts to pull up with the liner, lay it back in place and use your spudger to secure it again.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Secure the adhesive: étape 44, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: étape 44, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: étape 44, image 3 de 3
      • Use a spudger to firmly press down on each of the six pieces of inner housing adhesive to secure them.
      • These pieces of adhesive can easily be pulled up when removing the final liners, so make sure they're firmly in place.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Connect the battery press connector: étape 45, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Connect the battery press connector: étape 45, image 2 de 2
      • Use your finger to align the battery press connector over its socket and press down to connect it.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement, Install the battery connector cover: étape 46, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Install the battery connector cover: étape 46, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Install the battery connector cover: étape 46, image 3 de 3
      • Use tweezers to hook the left edge of the battery connector cover into place, then lay the cover down flat.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement: étape 47, image 1 de 2 Google Pixel 9a Wide Camera Replacement: étape 47, image 2 de 2
      • Use a 3IP Torx Plus screwdriver to install the 1.7 mm‑long screw securing the battery connector cover.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Install the wireless charging assembly: étape 48, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Install the wireless charging assembly: étape 48, image 2 de 2
      • Place the wireless charging assembly onto the frame.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement: étape 49, image 1 de 3 Google Pixel 9a Wide Camera Replacement: étape 49, image 2 de 3 Google Pixel 9a Wide Camera Replacement: étape 49, image 3 de 3
      • Use your fingers to firmly press around the perimeter of the wireless charging assembly to re‑engage all of its clips.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Install the wireless charging assembly screws: étape 50, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Install the wireless charging assembly screws: étape 50, image 2 de 2
      • Use a Torx Plus 3IP screwdriver to install the 16 screws securing the wireless charging assembly:
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: étape 51, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: étape 51, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: étape 51, image 3 de 3
      • Take your time during the next two steps. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      • When removing the rear cover adhesive during this step, be very careful not to damage the battery or any of the fragile components near the perimeter of the frame.
      • Use a spudger and tweezers to scrape up and remove all the old rear cover adhesive from the perimeter of your phone.
      • If you scrape up a piece big enough to grip with your fingers, you can pull long sections of the adhesive up. Pull slowly and straight in the opposite direction of the adhesive.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement, Clean the frame: étape 52, image 1 de 1
      • Using some high-concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter), clean the areas of the frame where the adhesive was.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Find the adhesive orientation: étape 53, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Find the adhesive orientation: étape 53, image 2 de 2
      • Before applying the rear cover adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
      • Hold the adhesive above the frame to find its orientation. Use the camera cutout in the liner to help visualize how it will lay on the frame.
      Demander à FixBot
    4. Google Pixel 9a Wide Camera Replacement, Peel the liner halfway down: étape 54, image 1 de 1
      • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
      Demander à FixBot
    5. Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 55, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 55, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 55, image 3 de 3
      • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved once you apply it.
      • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
      • Use the lip of the frame to help align the adhesive.
      • Once the top edge is properly aligned, gently press down on the top corners with your fingers to secure the adhesive.
      Demander à FixBot
    6. Google Pixel 9a Wide Camera Replacement: étape 56, image 1 de 3 Google Pixel 9a Wide Camera Replacement: étape 56, image 2 de 3 Google Pixel 9a Wide Camera Replacement: étape 56, image 3 de 3
      • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
      Demander à FixBot
    7. Google Pixel 9a Wide Camera Replacement, Remove the top liner: étape 57, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the top liner: étape 57, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the top liner: étape 57, image 3 de 3
      • Use the pull tab to remove the large, colored liner.
      Demander à FixBot
    8. Google Pixel 9a Wide Camera Replacement, Secure the adhesive: étape 58, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: étape 58, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: étape 58, image 3 de 3
      • Use a spudger to press down firmly on the adhesive around the perimeter of your phone to secure it to the frame.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the old camera bezel adhesive: étape 59, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the old camera bezel adhesive: étape 59, image 2 de 2
      • If the camera bezel detached when removing the rear cover, follow the next five steps to install it. Otherwise, skip down five steps.
      • Use a spudger to scrape up and remove any of the old adhesive from the camera bezel and its corresponding spot on the rear cover.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement, Remove the adhesive residue: étape 60, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the adhesive residue: étape 60, image 2 de 2
      • Use high-concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any adhesive residue from the camera bezel and its corresponding spot on the rear cover.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 61, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 61, image 2 de 2
      • Remove the large, clear liner from the camera bezel adhesive.
      • Put the adhesive over the top of the camera bezel and set it in place.
      Demander à FixBot
    4. Google Pixel 9a Wide Camera Replacement: étape 62, image 1 de 3 Google Pixel 9a Wide Camera Replacement: étape 62, image 2 de 3 Google Pixel 9a Wide Camera Replacement: étape 62, image 3 de 3
      • Use a spudger to firmly press around the perimeter of the camera bezel to secure the adhesive.
      • Remove the second, colored liner from the camera bezel adhesive.
      Demander à FixBot
    5. Google Pixel 9a Wide Camera Replacement, Install the camera bezel: étape 63, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Install the camera bezel: étape 63, image 2 de 2
      • Align the camera bezel such that the square foam is closest to the edge.
      • Use your fingers to press the camera bezel into place on the rear cover, squeezing firmly around the perimeter to secure it with the adhesive.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: étape 64, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the old rear cover adhesive: étape 64, image 2 de 2
      • Use the flat end of a spudger to scrape up and remove any all the old adhesive that stayed on the back cover, including the five pieces of small, oval‑shaped adhesive.
      • If you don't see all the oval adhesives, some might've stuck to the phone frame.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement: étape 65, image 1 de 1
      • Use high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter) to clean up and remove any residue from the adhesives you removed.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 66, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Apply the adhesive: étape 66, image 2 de 2
      • Remove the larger, clear liner from the back cover inner adhesive.
      • Lay the adhesive onto the bottom of the back cover, making sure the cutout goes around the camera bezel.
      Demander à FixBot
    4. Google Pixel 9a Wide Camera Replacement, Secure the adhesive: étape 67, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Secure the adhesive: étape 67, image 2 de 2
      • Use your fingers or a spudger to firmly push down on the five small adhesives to secure them to the back cover.
      • Slowly peel up and remove the remaining liner.
      • If the adhesives start to peel up with the liner, lay it back down and use your spudger to secure the adhesive again.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the lens cap: étape 68, image 1 de 2 Google Pixel 9a Wide Camera Replacement, Remove the lens cap: étape 68, image 2 de 2
      • Remove any lens cap or liners from the wide camera.
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Remove the remaining liners: étape 69, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Remove the remaining liners: étape 69, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Remove the remaining liners: étape 69, image 3 de 3
      • Use the point of a spudger to lift and remove the plastic liners from the adhesive around the rear cameras.
      Demander à FixBot
    2. Google Pixel 9a Wide Camera Replacement: étape 70, image 1 de 2 Google Pixel 9a Wide Camera Replacement: étape 70, image 2 de 2
      • Use the pull tabs to remove the final liner from the rear cover adhesive.
      Demander à FixBot
    3. Google Pixel 9a Wide Camera Replacement, Install the rear cover: étape 71, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Install the rear cover: étape 71, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Install the rear cover: étape 71, image 3 de 3
      • Align the rear cover over the frame and press it into place.
      Demander à FixBot
    4. Google Pixel 9a Wide Camera Replacement: étape 72, image 1 de 3 Google Pixel 9a Wide Camera Replacement: étape 72, image 2 de 3 Google Pixel 9a Wide Camera Replacement: étape 72, image 3 de 3
      Demander à FixBot
    1. Google Pixel 9a Wide Camera Replacement, Install the SIM card tray: étape 73, image 1 de 3 Google Pixel 9a Wide Camera Replacement, Install the SIM card tray: étape 73, image 2 de 3 Google Pixel 9a Wide Camera Replacement, Install the SIM card tray: étape 73, image 3 de 3
      • Push the SIM card tray completely into its slot on the bottom edge of your phone.
      Demander à FixBot
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
Membre depuis le 09/14/22
199 976 Réputation
1 243 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
82 989 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 15
30 derniers jours : 41
Total : 700
