Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Google Pixel Buds 2a Charging Case Battery Replacement
Ce dont vous avez besoin
    1. Google Pixel Buds 2a Charging Case Battery Replacement, Unplug the charging case: étape 1, image 1 de 1
      • Before starting your repair, unplug your charging case.
      Demander à FixBot
      Ajouter un commentaire
    2. Google Pixel Buds 2a Charging Case Battery Replacement, Remove the Buds: étape 2, image 1 de 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the Buds: étape 2, image 2 de 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the Buds: étape 2, image 3 de 3
      • Open the case lid, remove the Pixel Buds, and set them aside.
      Demander à FixBot
    3. Google Pixel Buds 2a Charging Case Battery Replacement, Remove the case screws: étape 3, image 1 de 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the case screws: étape 3, image 2 de 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the case screws: étape 3, image 3 de 3
      • Use a T5 Torx screwdriver to remove the two 6.2 mm‑long screws from the ear bud recesses.
      • You may need to flip the case over and gently shake it to get the screws to fall out.
      Demander à FixBot
    4. Google Pixel Buds 2a Charging Case Battery Replacement, Remove the bottom shell: étape 4, image 1 de 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the bottom shell: étape 4, image 2 de 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the bottom shell: étape 4, image 3 de 3
      • Slide the main body of the charging case completely out of the bottom shell, inserting a fingernail in the seam near the top of the case to create an initial gap.
      • If you're having trouble, use the flat end of a spudger to start the initial gap.
      Demander à FixBot
    1. Google Pixel Buds 2a Charging Case Battery Replacement, Remove the battery: étape 5, image 1 de 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the battery: étape 5, image 2 de 3 Google Pixel Buds 2a Charging Case Battery Replacement, Remove the battery: étape 5, image 3 de 3
      • Grip the small green tab on the back of the charging case and pull the battery out of its recess.
      • The battery fits snugly in place—this may take a little bit of force.
      Demander à FixBot
Spencer Day
Membre depuis le 09/14/22
198 922 Réputation
1 243 tutoriels rédigés
1 commentaire de tutoriel
Great instructions, am I missing something because surely we'd need to know what cell is needed for replacement.
D R - Réponse Partager
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 41
30 derniers jours : 184
Total : 2,314
