Aller au contenu principal
Google Pixel Slate Front-Facing Camera Replacement
Ce dont vous avez besoin
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: étape 1, image 1 de 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: étape 1, image 2 de 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: étape 1, image 3 de 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Front-Facing Camera Replacement: étape 2, image 1 de 3 Google Pixel Slate Front-Facing Camera Replacement: étape 2, image 2 de 3 Google Pixel Slate Front-Facing Camera Replacement: étape 2, image 3 de 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: étape 3, image 1 de 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: étape 3, image 2 de 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: étape 3, image 3 de 3
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: étape 4, image 1 de 3 Google Pixel Slate Front-Facing Camera Replacement: étape 4, image 2 de 3 Google Pixel Slate Front-Facing Camera Replacement: étape 4, image 3 de 3
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: étape 5, image 1 de 2 Google Pixel Slate Front-Facing Camera Replacement: étape 5, image 2 de 2
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: étape 6, image 1 de 2 Google Pixel Slate Front-Facing Camera Replacement: étape 6, image 2 de 2
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
2 autres ont terminé cette réparation.
Spencer Alonge
Membre depuis le 04/18/19
648 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S2-G5, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 15
Total : 803
