Aller au contenu principal
Google Pixel Slate Speaker Replacement
Ce dont vous avez besoin
  1. Google Pixel Slate Speaker Replacement, Screen: étape 1, image 1 de 3 Google Pixel Slate Speaker Replacement, Screen: étape 1, image 2 de 3 Google Pixel Slate Speaker Replacement, Screen: étape 1, image 3 de 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: étape 2, image 1 de 3 Google Pixel Slate Speaker Replacement: étape 2, image 2 de 3 Google Pixel Slate Speaker Replacement: étape 2, image 3 de 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: étape 3, image 1 de 3 Google Pixel Slate Speaker Replacement, Speaker: étape 3, image 2 de 3 Google Pixel Slate Speaker Replacement, Speaker: étape 3, image 3 de 3
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: étape 4, image 1 de 1
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: étape 5, image 1 de 2 Google Pixel Slate Speaker Replacement: étape 5, image 2 de 2
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: étape 6, image 1 de 2 Google Pixel Slate Speaker Replacement: étape 6, image 2 de 2
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: étape 7, image 1 de 2 Google Pixel Slate Speaker Replacement: étape 7, image 2 de 2
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: étape 8, image 1 de 3 Google Pixel Slate Speaker Replacement: étape 8, image 2 de 3 Google Pixel Slate Speaker Replacement: étape 8, image 3 de 3
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: étape 9, image 1 de 1
    • You can now remove the speaker from the device.
3 autres ont terminé cette réparation.
Spencer Alonge
Membre depuis le 04/18/19
648 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S2-G5, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 9
Total : 872
