Aller au contenu principal
Google Pixel XL Display Assembly Replacement
Ce dont vous avez besoin
  1. Google Pixel XL Display Assembly Replacement, Display Assembly: étape 1, image 1 de 3 Google Pixel XL Display Assembly Replacement, Display Assembly: étape 1, image 2 de 3 Google Pixel XL Display Assembly Replacement, Display Assembly: étape 1, image 3 de 3
    • Heat an iOpener and apply it to the top edge of the display for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • Take note of the following regions before you begin prying:
    • Thin adhesive lined against the display panel
    • Thick adhesive
    • The OLED display panel, which is very prone to damage
    • The display cable, which can be damaged during prying
  2. Google Pixel XL Display Assembly Replacement: étape 2, image 1 de 3 Google Pixel XL Display Assembly Replacement: étape 2, image 2 de 3 Google Pixel XL Display Assembly Replacement: étape 2, image 3 de 3
    • Once the edge is warm to the touch, apply a suction cup close to the edge.
    • Lift on the suction cup, and insert an opening pick into the gap.
    • Do not insert the pick more than 13 mm (0.5 inches), or you will damage the display assembly.
    • If you have trouble creating a gap, reheat the edge and try again.
    • You can also try to use a playing card instead of an opening pick to help make the initial entry.
  3. Google Pixel XL Display Assembly Replacement: étape 3, image 1 de 3 Google Pixel XL Display Assembly Replacement: étape 3, image 2 de 3 Google Pixel XL Display Assembly Replacement: étape 3, image 3 de 3
    • Slide the opening clip across the top edge to slice through the adhesive.
    • Be sure not to cut deeper than 13 mm (0.5 inches) or you will damage the display.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    • Leave an opening pick in the edge to prevent the adhesive from resealing.
  4. Google Pixel XL Display Assembly Replacement: étape 4, image 1 de 3 Google Pixel XL Display Assembly Replacement: étape 4, image 2 de 3 Google Pixel XL Display Assembly Replacement: étape 4, image 3 de 3
    • Heat an iOpener and apply it to the right edge of the phone for two minutes.
    • Insert an opening pick near the top edge of the phone, where you have already sliced the adhesive.
    • Slowly guide the pick around the right corner.
    • Carefully slide the pick down the right edge of the phone to slice through the adhesive.
    • Do not insert the pick more than 1 mm (1/32") along the edge, or you will damage the display assembly.
    • Repeat the step for the left edge of the phone.
  5. Google Pixel XL Display Assembly Replacement: étape 5, image 1 de 2 Google Pixel XL Display Assembly Replacement: étape 5, image 2 de 2
    • Heat the bottom edge with an iOpener for two minutes.
    • Insert a pick near the right edge where you have already loosened the adhesive.
    • Carefully guide the pick around the corner.
    • Slide the pick along the bottom edge to slice through the adhesive.
    • Do not slice deeper than 8.5 mm (1/3") or you will damage the display cable.
  6. Google Pixel XL Display Assembly Replacement: étape 6, image 1 de 1
    • Once you have sliced around the perimeter of the phone, carefully lift the display assembly up slightly by the right corners.
    • Do not attempt to remove the display assembly. It is still attached by a flex cable.
    • Use an opening pick to slice through any remaining adhesive.
  7. Google Pixel XL Display Assembly Replacement: étape 7, image 1 de 3 Google Pixel XL Display Assembly Replacement: étape 7, image 2 de 3 Google Pixel XL Display Assembly Replacement: étape 7, image 3 de 3
    • Lift the display assembly from the top end and swing it around such that it rests upside down on the frame.
    • Be careful not to strain the flex cable when you swing the assembly around.
    • Remove the two 4 mm T5 screws securing the display cable bracket.
    • Remove the display cable bracket.
  8. Google Pixel XL Display Assembly Replacement: étape 9, image 1 de 2 Google Pixel XL Display Assembly Replacement: étape 9, image 2 de 2
    • Use the point of a spudger to pry up and disconnect the display cable from its connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  9. Google Pixel XL Display Assembly Replacement: étape 10, image 1 de 3 Google Pixel XL Display Assembly Replacement: étape 10, image 2 de 3 Google Pixel XL Display Assembly Replacement: étape 10, image 3 de 3
    • Remove the display assembly.
    • For comprehensive instructions on how to reinstall the Pixel XL display, follow this guide.
    • If your replacement display did not come with a speaker grille, use tweezers to gently peel the adhesive grille from your old display, and transfer it to the replacement.
    • Before installing a new display, be sure to remove all traces of adhesive from the frame. Use a spudger or an opening tool to scrape it off, and use high-concentration isopropyl alcohol to remove any residue.
    • If you are reinstalling the same display assembly, be sure to remove all adhesive residue from the panel and the frame before applying new adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
If your Pixel won't turn on after replacing the screen, there is a chance that the phone has silently turned on when the battery is re-connected. Hold the power button for a few seconds until the phone vibrates off. Afterwards, re-connect the screen, and try again.
Repair didn’t go as planned? Check out our Google Pixel XL Answers community for troubleshooting help.
33 autres ont terminé cette réparation.
Arthur Shi
Membre depuis le 01/03/18
237 362 Réputation
474 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
142 membres
16 164 tutoriels rédigés
11 commentaires
I just connected the screen to the phone, but the screen doesn’t start. Do I have to restart in a special way the phone to make it works? All possible button combinations to restart the phone doesn’t work
David Torralbo - Réponse
The iFixIt iOpener tool is a complete waste of money. It didn’t loosen up the glue at all. I am requesting a refund on Amazon.com
Drew Hookway - Réponse
Hi Drew, sorry to hear that your iOpener didn’t work too well in your repairs. We like to think it’s a pretty valuable and inexpensive tool, but it does have its quirks — namely, not everyone’s microwave is specced to operate at the same temperatures, so not everyone will achieve the most optimal temperature during that heating process.
For what it’s worth, we do put a Lifetime Warranty on the iOpener tools, so our Support team would be happy to replace that one for you, if you’d like. If so, please reach out to them by using the Contact link on the help page: http://help.ifixit.com. Otherwise, you are welcome to request a refund via Amazon and we will oblige.
We wish you all the best in your future repairs.
Kadan Sharpe -
I am sure the iOpener does work, but it probably takes a long time to heat the adhesive enough for screen removal and would require several applications. I got one as part of my screen replacement kit, although I have a heat gun so I didn’t end up using it. That being said my screen took at least four minutes of heating, with some re-heating to remove the broken shards. I would also imagine that adhesives vary from manufacturer, since this is my first screen replacement all I know is that the adhesive on the Pixel XL is really strong!
Dan E -
Don’t forget to transfer the speaker cloth to the new screen. I got it all back together before realizing that there was just an ugly hole.
John-Paul Andrusky - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 79
Total : 30,071
