Introduction
In this guide, you will learn how to remove the back panel of the Google Pixelbook in order to replace the battery. Since the back panel is heavily adhered to the batteries, it is near impossible to remove them without causing damage. We strongly recommend purchasing a whole new back panel/battery pack instead of attempting to separate them.
Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
  • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
  • Peel the linings off completely until the back of the Pixelbook looks bare.
Ajouter un commentaire
Remove the top yellow 2.0mm screws by using a T3 Torx screwdriver to turn the screws counterclockwise.
  • Remove the top yellow 2.0mm screws by using a T3 Torx screwdriver to turn the screws counterclockwise.
  • Remove the rest of the screws from the back panel with a T5 Torx screwdriver. Turn the black 3.0mm screws and the silver 3.0mm screws counterclockwise.
  • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
  • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  • Remove the small, black casing by using the spudger to lift it up from its place.
  • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
  • Your back panel is now free from the main component.
Megan Phillips
Membre depuis le 24/01/2018
181 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S18-G1, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 16
7 derniers jours : 81
30 derniers jours : 344
Total : 1,424
