Aller au contenu principal
Google Pixelbook Left Charging Port Replacement
Ce dont vous avez besoin
  1. Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): étape 1, image 1 de 3 Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): étape 1, image 2 de 3 Google Pixelbook Left Charging Port Replacement, Battery (Back Panel): étape 1, image 3 de 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Left Charging Port Replacement: étape 2, image 1 de 2 Google Pixelbook Left Charging Port Replacement: étape 2, image 2 de 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Left Charging Port Replacement: étape 3, image 1 de 3 Google Pixelbook Left Charging Port Replacement: étape 3, image 2 de 3 Google Pixelbook Left Charging Port Replacement: étape 3, image 3 de 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Left Charging Port Replacement: étape 4, image 1 de 3 Google Pixelbook Left Charging Port Replacement: étape 4, image 2 de 3 Google Pixelbook Left Charging Port Replacement: étape 4, image 3 de 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Left Charging Port Replacement: étape 5, image 1 de 2 Google Pixelbook Left Charging Port Replacement: étape 5, image 2 de 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Left Charging Port Replacement: étape 6, image 1 de 2 Google Pixelbook Left Charging Port Replacement: étape 6, image 2 de 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Left Charging Port Replacement: étape 7, image 1 de 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Left Charging Port Replacement, Left Charging Port: étape 8, image 1 de 2 Google Pixelbook Left Charging Port Replacement, Left Charging Port: étape 8, image 2 de 2
    • Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
  9. Google Pixelbook Left Charging Port Replacement: étape 9, image 1 de 2 Google Pixelbook Left Charging Port Replacement: étape 9, image 2 de 2
    • Disconnect the thin, black and white cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Left Charging Port Replacement: étape 10, image 1 de 1
    • Remove the thin, black component by pulling it up and out of the laptop with your fingers.
    • This photo shows the bottom screw still in the black box, but yours should be removed.
  11. Google Pixelbook Left Charging Port Replacement: étape 11, image 1 de 1
    • Remove the gold 2.0mm corner screw by turning it counterclockwise with a T3 Torx screwdriver.
  12. Google Pixelbook Left Charging Port Replacement: étape 12, image 1 de 2 Google Pixelbook Left Charging Port Replacement: étape 12, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using needle-nose tweezers, remove the silver casing by lifting it up and out of the computer.
  13. Google Pixelbook Left Charging Port Replacement: étape 13, image 1 de 2 Google Pixelbook Left Charging Port Replacement: étape 13, image 2 de 2
    • Remove the three 3.0mm black screws on the right side by using a T5 Torx screwdriver to turn the screws counterclockwise.
    • Remove the silver 2.0mm screw on the left side by using a T3 Torx screwdriver to turn the screw counterclockwise.
  14. Google Pixelbook Left Charging Port Replacement: étape 14, image 1 de 1
    • Disconnect the thin, black ribbon cable by using the spudger to lift it up from the computer.
  15. Google Pixelbook Left Charging Port Replacement: étape 15, image 1 de 2 Google Pixelbook Left Charging Port Replacement: étape 15, image 2 de 2
    • Use the needle-nose tweezers to remove the charging port by lifting the component up and out of the Pixelbook.
Alon Gary
Membre depuis le 01/24/18
550 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 membres
7 tutoriels rédigés
3 commentaires
Where to get replacemt charging port from please
kamil Szym - Réponse
Where can we get a replacement charging port for the Pixelbook Go 2 (i7)?
michaelnic - Réponse
Hi Michael, did you manage to find the charging port and replace it for the Pixelbook Go?
redshift galaxy -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 40
Total : 2,867
