Aller au contenu principal
Google Pixelbook Right Charging Port Replacement
Ce dont vous avez besoin
  1. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): étape 1, image 1 de 3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): étape 1, image 2 de 3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): étape 1, image 3 de 3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Right Charging Port Replacement: étape 2, image 1 de 2 Google Pixelbook Right Charging Port Replacement: étape 2, image 2 de 2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Right Charging Port Replacement: étape 3, image 1 de 3 Google Pixelbook Right Charging Port Replacement: étape 3, image 2 de 3 Google Pixelbook Right Charging Port Replacement: étape 3, image 3 de 3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Right Charging Port Replacement: étape 4, image 1 de 3 Google Pixelbook Right Charging Port Replacement: étape 4, image 2 de 3 Google Pixelbook Right Charging Port Replacement: étape 4, image 3 de 3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Right Charging Port Replacement: étape 5, image 1 de 2 Google Pixelbook Right Charging Port Replacement: étape 5, image 2 de 2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Right Charging Port Replacement: étape 6, image 1 de 2 Google Pixelbook Right Charging Port Replacement: étape 6, image 2 de 2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Right Charging Port Replacement: étape 7, image 1 de 1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Right Charging Port Replacement, Right Charging Port: étape 8, image 1 de 2 Google Pixelbook Right Charging Port Replacement, Right Charging Port: étape 8, image 2 de 2
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
  9. Google Pixelbook Right Charging Port Replacement: étape 9, image 1 de 1
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Right Charging Port Replacement: étape 10, image 1 de 1
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
  11. Google Pixelbook Right Charging Port Replacement: étape 11, image 1 de 1
    • Remove the small, red component by lifting it up with the spudger.
  12. Google Pixelbook Right Charging Port Replacement: étape 12, image 1 de 1
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
  13. Google Pixelbook Right Charging Port Replacement: étape 13, image 1 de 2 Google Pixelbook Right Charging Port Replacement: étape 13, image 2 de 2
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
Alon Gary
Membre depuis le 01/24/18
526 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S18-G1, Livingston Winter 2018 Membre de l'équipe Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,579
