Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Governor Adjustment
Ce dont vous avez besoin
  1. Governor Adjustment, Governor Adjustment: étape 1, image 1 de 3 Governor Adjustment, Governor Adjustment: étape 1, image 2 de 3 Governor Adjustment, Governor Adjustment: étape 1, image 3 de 3
    • Before starting, make sure the engine isn't running and is not hot.
    • Using needle-nose pliers, carefully unhook the spring from the end opposite the air filter.
  2. Governor Adjustment: étape 2, image 1 de 1
    • Use the needle-nose pliers to either lengthen or shorten the hook at the end of the spring.
    • If your engine is stalling or refusing to start, try shortening the spring. This will enable more fuel to reach to engine at idle. If the engine is bogged down when running and you hear liquids splashing, try lengthening the spring.
  3. Governor Adjustment: étape 3, image 1 de 1
    • Carefully re-hook the spring on the arm it was disconnected from.
Aaron Correya
Membre depuis le 04/19/18
239 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S25-G15, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 membres
7 tutoriels rédigés
2 commentaires de tutoriel
Wow, I'm very grateful.
Bradley Earnest - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 9
30 derniers jours : 34
Total : 3,071
