Aller au contenu principal
Graco Secure Coverage Vibrator Replacement on Parent Unit
Ce dont vous avez besoin
  1. Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Battery: étape 1, image 1 de 3 Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Battery: étape 1, image 2 de 3 Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Battery: étape 1, image 3 de 3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage Vibrator Replacement on Parent Unit: étape 2, image 1 de 1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
  3. Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Vibrator: étape 3, image 1 de 2 Graco Secure Coverage Vibrator Replacement on Parent Unit, Parent Unit Vibrator: étape 3, image 2 de 2
    • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
  4. Graco Secure Coverage Vibrator Replacement on Parent Unit: étape 4, image 1 de 2 Graco Secure Coverage Vibrator Replacement on Parent Unit: étape 4, image 2 de 2
    • Using opening plastic tool, pry the two grey cases from both sides of the device.
    • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
    • While pry off the grey cases, hold the device with your other hand to remove the cases.
  5. Graco Secure Coverage Vibrator Replacement on Parent Unit: étape 5, image 1 de 1
    • Pry the edges of the device to separate the front case away from the rare case.
    • While prying the edges, hold the device with one hand to pull out each case a part.
    • Make sure you use a constant force, and the pushbuttons are pried off completely.
  6. Graco Secure Coverage Vibrator Replacement on Parent Unit: étape 6, image 1 de 2 Graco Secure Coverage Vibrator Replacement on Parent Unit: étape 6, image 2 de 2
    • Remove the 7mm Phillips #1 screw from the mother board.
    • Place the screw in a secure place.
  7. Graco Secure Coverage Vibrator Replacement on Parent Unit: étape 7, image 1 de 1
    • Pick up the motherboard carefully.
    • Using plastic opening tool, pry and remove the vibrator part.
  8. Graco Secure Coverage Vibrator Replacement on Parent Unit: étape 8, image 1 de 1
    • Solder off vibrator from the motherboard.
    • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the vibrator wires.
    • Replace the vibrator.
Ahmed Elshaer
Membre depuis le 09/09/15
201 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 6-5, Remmell Fall 2015 Membre de l'équipe USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 527
