Aller au contenu principal
Pour réparer ensemble - Je crée un compte
GravityLight Motor Replacement
Ce dont vous avez besoin
    1. GravityLight Motor Replacement, Removing the Front Panel: étape 1, image 1 de 2 GravityLight Motor Replacement, Removing the Front Panel: étape 1, image 2 de 2
      • Flip the GravityLight on its back and place it on a sturdy surface.
      • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
      Demander à FixBot
      Ajouter un commentaire
    2. GravityLight Motor Replacement, Opening the Device Housing: étape 2, image 1 de 1
      • Some of the internal pieces may loosen or fall out during disassembly.
      • Firmly grasp both parts of the GravityLight body and pull them apart.
      Demander à FixBot
    1. GravityLight Motor Replacement, Isolating the Back Panel: étape 3, image 1 de 1
      • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
      Demander à FixBot
    2. GravityLight Motor Replacement, Removing the Back Panel Screws: étape 4, image 1 de 1
      • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
      • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
      Demander à FixBot
    3. GravityLight Motor Replacement, Removing the LED Housing: étape 5, image 1 de 1
      • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
      • Gently lift off the LED housing (the white disk).
      • Set the LED housing on the table next to the body of the device.
      Demander à FixBot
    4. GravityLight Motor Replacement, Removing White Frame and Gear: étape 6, image 1 de 1
      • Lift off the white piece with four arms.
      • Lift off the black-rimmed gear.
      • Set both pieces aside in a safe place.
      Demander à FixBot
    5. GravityLight Motor Replacement, Removing the Motor Screws: étape 7, image 1 de 1
      • Remove the two 2cm Phillips 00 screws from the motor housing.
      • The spring pushing the motor housing may pop out once the motor has been removed.
      Demander à FixBot
    6. GravityLight Motor Replacement, Separating the Back Panel Housing: étape 8, image 1 de 3 GravityLight Motor Replacement, Separating the Back Panel Housing: étape 8, image 2 de 3 GravityLight Motor Replacement, Separating the Back Panel Housing: étape 8, image 3 de 3
      • Firmly grasp both parts of the back panel and pull them apart.
      Demander à FixBot
    7. GravityLight Motor Replacement, Removing the Motor: étape 9, image 1 de 3 GravityLight Motor Replacement, Removing the Motor: étape 9, image 2 de 3 GravityLight Motor Replacement, Removing the Motor: étape 9, image 3 de 3
      • Place the middle section flat with the side that holds the gear system down and locate the back of the motor.
      • Clip the wires close to the soldered joints.
      • Lift the motor out of the middle section. Using the flush wire cutters, clip the red and the blue wires located on the motor's back.
      Demander à FixBot
    8. GravityLight Motor Replacement, Soldering the New Motor: étape 10, image 1 de 1
      Demander à FixBot
Anthony Jungquist
Membre depuis le 09/26/14
125 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 12-2, Forte Fall 2014 Membre de l'équipe Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 membres
84 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 32
30 derniers jours : 53
Total : 2,621
