Introduction
This guide will teach the user how to install the right side panel and align the buttons correctly. It will also focus on the restoration of functionality of the device and show the proper placement of the buttons to restore the device to its retail form.
Pièces
Aucune pièce nécessaire.
Use the plastic opening tool.
  • Use the plastic opening tool.
  • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
Ajouter un commentaire
The side panel can now be detached using your fingers.
  • The side panel can now be detached using your fingers.
  • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
  • Ensure that the elevated grating is on the left side of the button, as seen in the first posted image.
  • Insert the button with the sound diagrams to the top section of the panel.
  • Ensure that the elevated grating is on the left side of the button, as seen in the posted image.
  • Insert the button with the two arrows to the bottom section of the panel.
  • Be careful with handling the panel during placement. Utilize gravity to keep the buttons from falling out.
  • Using your fingers, carefully click in the bottom end of the panel, followed by the top end of the panel.
  • Apply pressure to both side panels simultaneously to ensure the device has restored original stability.
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
Membre depuis le 09/03/2012
101 Réputation
9 tutoriels rédigés
Équipe
Clemson, Team 15-3, Benson Spring 2012 Membre de l'équipe Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 838
