Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
If you have just bought your skateboard deck, strip the plastic from it and remove any stickers that are on the top of the deck where the grip tape will be applied. Be sure to have all of your tools and materials close by to make the installation process faster and more efficient.
Pièces
Aucune pièce spécifiée.
  1. Peel off the paper backing from the sheet of grip tape.
    • Peel off the paper backing from the sheet of grip tape.
    • Make sure you do not fold or wrinkle the grip tape.
  2. Center the sheet of grip tape evenly over the top of the skateboard deck.
    • Center the sheet of grip tape evenly over the top of the skateboard deck.
  3. Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form. Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
    • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
  4. Use a screwdriver to scrape along the edges of the skateboard.  This will remove some of the grip around the edges making the trimming process easier on you and your equipment. You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
    • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
    • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
  5. Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape. Angle your knife towards the inside of the skateboard to make it easier to cut a straight line. Be careful when using the utility knife and always keep it pointed away from yourself and others.
    • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
    • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
    • Be careful when using the utility knife and always keep it pointed away from yourself and others.
  6. Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Use caution when sanding as the grip tape can become heated.
  7. If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
    • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
  8. After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed. After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
    • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
4 autre(s) ont terminé cette réparation.
Jared Stine
Membre depuis le 05/10/2012
756 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-32, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 membres
6 tutoriels rédigés
Our lightning protection / earthing product range includes products for protecting buildings from mechanical destruction caused by lightning effects and the associated risk of fire. We stock a range of electrical earthing and lightning protection products, protecting critical systems and buildings in the event of over-voltage lightning strikes. W have Copper rods sleeve cladded type ,rod clamp ,p clamp, C clamp, w clamp, clamps earth, pre-fabricated concrete pit, copper bus bar ,earthing strip tape, cross L joint clamp solid conductor , terminal test point insulator. jumpers , braid ,earthing network services for installation, earthing material powder, man hole cover, bare copper conductor , cad weld mold,cad weld powder cartridge  and core cutting.
<a href="http://www.alfazalengineering.com/uni-st...>uni strut channels and accessories/</a>
alfazal engineering - Réponse
Great tutorial on how to apply skateboard griptape, we will be selling custom griptape on our website for those that want to add a new custom look to their deck. Check us out at www.skateboardstickerz.com
kaldwelreycabugao - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 50
Total : 6,531
