Aller au contenu principal
Guitar Nut Replacement
Ce dont vous avez besoin
  1. Guitar Nut Replacement, Guitar Nut: étape 1, image 1 de 2 Guitar Nut Replacement, Guitar Nut: étape 1, image 2 de 2
    • Turn the knobs to unwind all guitar strings currently on the guitar.
    • For this type of guitar turn the knobs on the right side clockwise and the left side counter-clockwise. Double-check this process by pulling the strings gently to see if the strings are losing tension.
  2. Guitar Nut Replacement: étape 2, image 1 de 2 Guitar Nut Replacement: étape 2, image 2 de 2
    • Cut around the guitar nut on the bottom and back side with a precision knife.
    • When cutting gently wedge the knife in using firm pressure, but using too much force may cause the knife to slip out.
  3. Guitar Nut Replacement: étape 3, image 1 de 1
    • Pry out the guitar nut using the precision knife.
    • Guitars with older glue can cause the nut to pop out of the groove unexpectedly during this step.
  4. Guitar Nut Replacement: étape 4, image 1 de 1
    • Sand away excess old glue in the groove of the guitar head.
    • Using the 80 grit sandpaper first is recommended, as this helps to remove tougher glue. Using the 120 grit sandpaper helps to smooth out the groove and eases laster steps.
  5. Guitar Nut Replacement: étape 5, image 1 de 2 Guitar Nut Replacement: étape 5, image 2 de 2
    • Sand the sides of the guitar nut until the guitar nut will fit in the grove of the guitar head.
    • Only the bottom and back of the new nut should be sanded.
  6. Guitar Nut Replacement: étape 6, image 1 de 2 Guitar Nut Replacement: étape 6, image 2 de 2
    • Glue in the guitar nut in the groove of the guitar head.
    • Glue may be placed on the groove of the guitar head or the bottom and the back of the guitar nut.
  7. Guitar Nut Replacement: étape 7, image 1 de 1
    • Rewind the strings back through the new nut.
    • For this type of guitar, turn the knobs in the opposite direction as in Step 1. As you rewind the guitar, the strings should become tenser.
Now that your guitar is repaired don’t forget to tune the guitar. The website https://guitar-tuner.org/ is an excellent resource for tuning your instrument.
Margaret Otto
Membre depuis le 02/21/22
145 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 11
Total : 738
