Aller au contenu principal
HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup)
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
  1. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup), Bacterial Filter: étape 1, image 1 de 1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): étape 2, image 1 de 1
    • Disconnect HME (heat and moisture exchanger) and flex tube
    • Bacterial filter is held within the HME.
    • Use both hands to gently pull and/or twist the flex tube and HME away from one another until fully disconnected.
    • The HME should still be connected to the overall circuit setup.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flex tube for this step.
  3. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): étape 3, image 1 de 1
    • Disconnect HME and circuit setup
    • Use both hands to gently pull and/or twist the flow sensor and HME away from one another until fully disconnected.
    • The HME (with used/contaminated bacterial filter) should now be completely disconnected from all parts.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flow sensor for this step.
Luisa Chiu
Membre depuis le 04/06/20
205 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S7-G11, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 membres
6 tutoriels rédigés
Un commentaire
Okay how offen should change out a carbon filter?
Bill Mcleod - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 22
Total : 724
