Aller au contenu principal
HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Air Filter: étape 1, image 1 de 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Air Filter: étape 1, image 2 de 2
    • Turn the Hamilton-C1 so that the rear view of the device is facing you.
    • Use your fingers to grasp the current air filter located at number 4 of the graphic and pull the filter out of the slot.
  2. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: étape 2, image 1 de 1
    • Insert a new air filter into the slot located at number 4.
  3. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Fan Filter: étape 3, image 1 de 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, Fan Filter: étape 3, image 2 de 2
    • Orient the Hamilton-C1 to the right side so that the gas connections are visible.
    • Grab and remove the fan filter located at location number 5 in the graphic.
  4. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: étape 4, image 1 de 1
    • Place a new fan filter into the designated slot.
  5. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, HEPA Filter: étape 5, image 1 de 2 HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement, HEPA Filter: étape 5, image 2 de 2
    • Orient the Hamilton-C1 so the back is facing you.
    • Remove the back panel as labeled by number 6 of the graphic using a Phillips #1 screwdriver.
  6. HAMILTON C-1 Preventative Maintenance for Air, Fan, and HEPA Filters Replacement: étape 6, image 1 de 1
    • Remove the current HEPA filter by pulling the filter outward and down.
    • Insert the new HEPA filter into the slot.
Tina Vo
Membre depuis le 04/06/20
538 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S7-G11, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 349
