Introduction
If the buttons on the HMDX Chill no longer function properly, you will need to disassemble and replace the buttons. This guide will walk you through removing the buttons from the HMDX Chill without breaking them. This guide also gives you information on how to replace new buttons easily.
Ce dont vous avez besoin
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Using a metal spudger, push the small latch upwards towards the button from the bottom of the base.
