Aller au contenu principal
HMDX Chill Motherboard Replacement
Ce dont vous avez besoin
  1. HMDX Chill Motherboard Replacement, Remove Rubber Base: étape 1, image 1 de 3 HMDX Chill Motherboard Replacement, Remove Rubber Base: étape 1, image 2 de 3 HMDX Chill Motherboard Replacement, Remove Rubber Base: étape 1, image 3 de 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Motherboard Replacement: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Motherboard Replacement: étape 3, image 1 de 2 HMDX Chill Motherboard Replacement: étape 3, image 2 de 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Motherboard Replacement, Motherboard: étape 4, image 1 de 3 HMDX Chill Motherboard Replacement, Motherboard: étape 4, image 2 de 3 HMDX Chill Motherboard Replacement, Motherboard: étape 4, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
  5. HMDX Chill Motherboard Replacement: étape 5, image 1 de 1
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
  6. HMDX Chill Motherboard Replacement: étape 6, image 1 de 3 HMDX Chill Motherboard Replacement: étape 6, image 2 de 3 HMDX Chill Motherboard Replacement: étape 6, image 3 de 3
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
  7. HMDX Chill Motherboard Replacement: étape 7, image 1 de 2 HMDX Chill Motherboard Replacement: étape 7, image 2 de 2
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
  8. HMDX Chill Motherboard Replacement: étape 8, image 1 de 1
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
Jourdan Holubasch
Membre depuis le 03/31/16
759 Réputation
7 tutoriels rédigés
Équipe
EWU-Giguere-S16S1G1 Membre de l'équipe EWU-Giguere-S16S1G1
Community
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 390
