Introduction
This guide provides steps for replacing a damaged Micro USB Jack on the HMDX Jam Plus. This guide requires previous soldering skill and utilizes a Micro Soldering Iron. This guide is should not be attempted by beginners. If performed incorrectly the device may not function anymore.
Ce dont vous avez besoin
Flip the device over so the bottom is facing up.
Use the large plastic opening tool to gently pry the rubber base from the device.
Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
