Aller au contenu principal
Introduction
The battery is attached to the back of the device's display. In this guide, you will desolder the battery connections to the motherboard and remove the battery from the device. This guide requires soldering; please be careful and ventilate the room.
Pièces
Aucune pièce spécifiée.
  1. Identify the SD card port.
    • Identify the SD card port.
  2. Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
  3. Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
    • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
  4. Fix Kits pour Android
    A new screen or battery is one kit away.
    Acheter maintenant
    Acheter maintenant
  5. Separate the back panel from the rest of the device.
    • Separate the back panel from the rest of the device.
  6. Desolder the battery connectors from the motherboard.
    • Desolder the battery connectors from the motherboard.
  7. Pull the bright blue-green tabs to remove the battery from the rest of the device.
    • Pull the bright blue-green tabs to remove the battery from the rest of the device.
    • Pulling the tabs may not fully disconnect the battery from the metal display casing.
  8. If the previous step is unsuccessful, wedge the smallest plastic opening tool between the adhesive and the metal display casing. Wedging may apply unsafe pressure on the battery. Be careful not to puncture the battery.
    • If the previous step is unsuccessful, wedge the smallest plastic opening tool between the adhesive and the metal display casing.
    • Wedging may apply unsafe pressure on the battery. Be careful not to puncture the battery.
Bryce Harmsen
Membre depuis le 25/09/2018
593 Réputation
5 tutoriels rédigés
Do you know where to buy a replacement battery for this device?
Nathan Wells - Réponse
Hi Nathan,
Unfortunately HP has not released this battery for sale to the public, as seen at https://parts.hp.com/hpparts/Search_Resu.... It may be worthwhile to contact HP. Here is an email address for their customer service: ''HPparts.sales.ams@hp.com.
Bryce Harmsen - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 5
30 derniers jours : 19
Total : 306
