Aller au contenu principal
HP 14-ac151nr DC Power Jack Replacement
Ce dont vous avez besoin
  1. HP 14-ac151nr DC Power Jack Replacement, Backplate: étape 1, image 1 de 1
    • Remove battery by pushing the two buttons inward.
  2. HP 14-ac151nr DC Power Jack Replacement: étape 2, image 1 de 1
    • Remove the two rubber feet next to the battery.
  3. HP 14-ac151nr DC Power Jack Replacement: étape 3, image 1 de 1
    • Remove all 14 Phillips head #0 screws.
  4. HP 14-ac151nr DC Power Jack Replacement: étape 4, image 1 de 1
    • Use a plastic opener tool to pry off the black backplate.
  5. HP 14-ac151nr DC Power Jack Replacement, DC Power Jack: étape 5, image 1 de 2 HP 14-ac151nr DC Power Jack Replacement, DC Power Jack: étape 5, image 2 de 2
    • Remove the black tape near the power jack.
    • Remove the screws connecting monitor to the bottom of the computer.
  6. HP 14-ac151nr DC Power Jack Replacement: étape 6, image 1 de 1
    • Position the metal fittings attached to the monitor out of the way.
    • The monitor is still attached by wires — be careful not to pull on it too hard.
  7. HP 14-ac151nr DC Power Jack Replacement: étape 7, image 1 de 3 HP 14-ac151nr DC Power Jack Replacement: étape 7, image 2 de 3 HP 14-ac151nr DC Power Jack Replacement: étape 7, image 3 de 3
    • Disconnect the power jack from the motherboard.
    • Remove the power jack by lifting it up.
    • An opener tool may make this easier.
Antonio Leonti
Membre depuis le 10/26/18
410 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G7, Simcock Fall 2018 Membre de l'équipe UMass Dartmouth, Team S1-G7, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G7
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 423
