Ce dont vous avez besoin
Turn the laptop over to its bottom so that the backside is facing you.
Using your fingers, push the two locking tabs inwards to release the battery.
Remove the battery from the device.
After removing the battery with the laptop on its back, expose screws that are hidden under the rubber feet and the center label.
Using the Phillips #0 screwdriver, remove fourteen (14) 6 mm screws from the back panel.
Disconnect the daughterboard from the connector with your thumb and pointer finger.
