Aller au contenu principal
HP 14-am052nr Motherboard Replacement
Ce dont vous avez besoin
  1. HP 14-am052nr Motherboard Replacement, Battery: étape 1, image 1 de 3 HP 14-am052nr Motherboard Replacement, Battery: étape 1, image 2 de 3 HP 14-am052nr Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Turn the laptop over to its bottom so that the backside is facing you.
    • Using your fingers, push the two locking tabs inwards to release the battery.
    • Remove the battery from the device.
  2. HP 14-am052nr Motherboard Replacement, Back Panel: étape 2, image 1 de 2 HP 14-am052nr Motherboard Replacement, Back Panel: étape 2, image 2 de 2
    • After removing the battery with the laptop on its back, expose screws that are hidden under the rubber feet and the center label.
    • Using the Phillips #0 screwdriver, remove fourteen (14) 6 mm screws from the back panel.
  3. HP 14-am052nr Motherboard Replacement: étape 3, image 1 de 2 HP 14-am052nr Motherboard Replacement: étape 3, image 2 de 2
    • Use a prying tool to remove the back panel from the base of the computer.
  4. HP 14-am052nr Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • Using the Phillips #0 screwdriver, remove three 3 mm screws and five 3.5 mm screws from the motherboard.
  5. HP 14-am052nr Motherboard Replacement: étape 5, image 1 de 2 HP 14-am052nr Motherboard Replacement: étape 5, image 2 de 2
    • Using the Phillips #0 screwdriver, remove four 1.5 mm screws from the silver cover.
    • Remove the silver cover from the device.
  6. HP 14-am052nr Motherboard Replacement: étape 6, image 1 de 3 HP 14-am052nr Motherboard Replacement: étape 6, image 2 de 3 HP 14-am052nr Motherboard Replacement: étape 6, image 3 de 3
    • Unplug all connectors attached to the motherboard.
  7. HP 14-am052nr Motherboard Replacement: étape 7, image 1 de 1
    • Once all plugs and screws disconnected, remove the motherboard from the device.
Matthew Heather
Membre depuis le 11/03/21
379 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 3-3, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G3
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 12
Total : 287
