Introduction
If your fan starts getting louder and your laptop starts to overheat it could be that you need to replace your fan. It's a simple replacement and would only need two tools a #1 Philip screwdriver and prying tools.
Ce dont vous avez besoin
Remove the eight 6 mm screws from the back panel using a Phillips #1 screwdriver.
Remove the rubber pads from the upper corners of the laptop to reveal two screws on each side.
Remove six 4 mm screws using a Phillips #1 screwdriver.
Pry the back panel off using an opening tool, working your way around the edges.
Remove the two 3 mm screws that secure the fan.
Gently disconnect the power cable; it can tear easily.
Remove the fan.
