Aller au contenu principal
HP 14-dq0051dx Back Case Replacement
Ce dont vous avez besoin
  1. HP 14-dq0051dx Back Case Replacement, Back Case: étape 1, image 1 de 2 HP 14-dq0051dx Back Case Replacement, Back Case: étape 1, image 2 de 2
    • Turn the laptop upside down so the backside is facing up.
    • Use a Phillips #1 screwdriver to remove eight screws from the back case.
  2. HP 14-dq0051dx Back Case Replacement: étape 2, image 1 de 1
    • Turn the laptop over and open the screen.
    • Insert the opening tool into the seam between the bottom panel and the keyboard.
    • Run the opening tool along the entire seam to separate the bottom panel.
    • You may hear clicking as you release the taps that secure the case.
  3. HP 14-dq0051dx Back Case Replacement: étape 3, image 1 de 1
    • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
    • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
Lily Mahaffee
Membre depuis le 01/18/23
430 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 282
