Introduction
Use this guide to replace the charging port of your HP 14-dq0051dx laptop. If the device is not charging, or the charging port has been damaged, this replacement should fix it. To tell if the charging port is in bad shape, shine a light into it and look closely. If there is anything bent or warped, it probably needs to be replaced.
Before beginning this repair, turn off the laptop and disconnect from the AC adapter.
Ce dont vous avez besoin
Turn the laptop upside down so the backside is facing up.
Use a Phillips #1 screwdriver to remove eight screws from the back case.
Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
Remove the battery from the laptop.
Use a Phillips #1 screwdriver to remove the two 4.5 mm screws from the left hinge.
Rotate the hinge up and out of the way.
