Introduction
Sometimes Charging ports die out due to water damage which can cause corrosion and damage the charging port. Dust and debris can build up over time and eventually cause damage. Wear and tear by using your phone's charging port regularly can eventually lead to a worn-out port.
We will provide an efficient and easy way to replace your charging port.
For this guide, we will be using the iFixit Precision Bit Driver, 15 Philips Screwdriver Bit(1.4 mm), Anti-Static Wrist Strap
Ce dont vous avez besoin
Turn laptop upside down exposing the screws.
Gently remove the rubber grips to reveal the remaining screws.
Using a Phillips head #1 screwdriver, remove all eight 2.5 mm screws.
