Aller au contenu principal
HP 14-dq0055dx RAM Replacement
Ce dont vous avez besoin
  1. HP 14-dq0055dx RAM Replacement, RAM: étape 1, image 1 de 3 HP 14-dq0055dx RAM Replacement, RAM: étape 1, image 2 de 3 HP 14-dq0055dx RAM Replacement, RAM: étape 1, image 3 de 3
    • Turn the laptop upside down exposing the screws.
    • Gently remove the rubber grips to reveal the remaining screws.
    • Using a Phillips #1 screwdriver remove all eight screws.
  2. HP 14-dq0055dx RAM Replacement: étape 2, image 1 de 1
    • Turn the laptop back over and open the screen.
    • Insert an opening tool into the seam between the keyboard and the bottom panel.
    • Run the opening tool along the seam to separate the back panel from the keyboard.
    • You may hear clicking as clips release the bottom panel from the keyboard.
  3. HP 14-dq0055dx RAM Replacement: étape 3, image 1 de 2 HP 14-dq0055dx RAM Replacement: étape 3, image 2 de 2
    • After the bottom panel has been separated from the laptop, close the laptop.
    • Flip the laptop back over.
    • Carefully place hands on either side of the laptop's back panel.
    • Lift up to remove the panel.
  4. HP 14-dq0055dx RAM Replacement: étape 4, image 1 de 3 HP 14-dq0055dx RAM Replacement: étape 4, image 2 de 3 HP 14-dq0055dx RAM Replacement: étape 4, image 3 de 3
    • Using a Phillips #1 screwdriver remove the four 2.5 mm screws securing the battery in place.
    • Remove the battery from the laptop by gently lifting up the bottom slightly.
    • Pull the battery toward you to remove.
    • Be wary of not bending the pins when pulling the battery out.
  5. HP 14-dq0055dx RAM Replacement: étape 5, image 1 de 3 HP 14-dq0055dx RAM Replacement: étape 5, image 2 de 3 HP 14-dq0055dx RAM Replacement: étape 5, image 3 de 3
    • Release the metal clasps on the sides of the RAM module by gently pulling away.
    • The RAM will spring upward and remain at an angle.
    • Pull the module out at the same angle.
    • Do not touch the gold pins on the RAM module.
Guy Medina
Membre depuis le 02/01/24
461 Réputation
3 tutoriels rédigés
Équipe
Gateway, Team 8-88, Gonzalez Spring 2024 Membre de l'équipe Gateway, Team 8-88, Gonzalez Spring 2024
GCC-GONZALEZ-S24S8G88
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 24
Total : 85
