Aller au contenu principal
HP 14-fq1025nr Keyboard Replacement
Ce dont vous avez besoin
  1. HP 14-fq1025nr Keyboard Replacement, Back Cover: étape 1, image 1 de 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Keyboard Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Keyboard Replacement: étape 3, image 1 de 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Keyboard Replacement: étape 4, image 1 de 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Keyboard Replacement: étape 5, image 1 de 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Keyboard Replacement, Battery: étape 6, image 1 de 2 HP 14-fq1025nr Keyboard Replacement, Battery: étape 6, image 2 de 2
    • Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Keyboard Replacement: étape 7, image 1 de 1
    • Remove the battery.
  8. HP 14-fq1025nr Keyboard Replacement, Fan: étape 8, image 1 de 1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  9. HP 14-fq1025nr Keyboard Replacement: étape 9, image 1 de 1
    J'achète
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  10. HP 14-fq1025nr Keyboard Replacement: étape 10, image 1 de 1
    • Remove the fan.
  11. HP 14-fq1025nr Keyboard Replacement, Heat Sink: étape 11, image 1 de 1
    • Remove the four gray 3 mm screws around the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  12. HP 14-fq1025nr Keyboard Replacement, Speakers: étape 12, image 1 de 2 HP 14-fq1025nr Keyboard Replacement, Speakers: étape 12, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the three black 5 mm screws holding down the speaker:
    • Two screws on the left side
    • One screw on the right side
  13. HP 14-fq1025nr Keyboard Replacement: étape 13, image 1 de 1
    J'achète
    • Unplug the speaker wire.
    • Use tweezers if needed.
  14. HP 14-fq1025nr Keyboard Replacement: étape 14, image 1 de 1
    • Remove the speaker.
  15. HP 14-fq1025nr Keyboard Replacement, SSD: étape 15, image 1 de 1
    • Remove the single 6 mm screw holding down the SSD using a Phillips #0 screwdriver.
  16. HP 14-fq1025nr Keyboard Replacement: étape 16, image 1 de 1
    • Slide the SSD out of the slot.
  17. HP 14-fq1025nr Keyboard Replacement, Motherboard: étape 17, image 1 de 3 HP 14-fq1025nr Keyboard Replacement, Motherboard: étape 17, image 2 de 3 HP 14-fq1025nr Keyboard Replacement, Motherboard: étape 17, image 3 de 3
    • Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
  18. HP 14-fq1025nr Keyboard Replacement: étape 18, image 1 de 2 HP 14-fq1025nr Keyboard Replacement: étape 18, image 2 de 2
    J'achète
    • Unplug the wire connections.
  19. HP 14-fq1025nr Keyboard Replacement: étape 19, image 1 de 1
    • Remove the motherboard.
    • Use the iFixit opening tool to pry it out if needed.
  20. HP 14-fq1025nr Keyboard Replacement, Screen: étape 20, image 1 de 3 HP 14-fq1025nr Keyboard Replacement, Screen: étape 20, image 2 de 3 HP 14-fq1025nr Keyboard Replacement, Screen: étape 20, image 3 de 3
    • Remove the four black 5 mm screws holding down the two silver screen hinges using a Phillips #00 screwdriver.
  21. HP 14-fq1025nr Keyboard Replacement: étape 21, image 1 de 2 HP 14-fq1025nr Keyboard Replacement: étape 21, image 2 de 2
    • Unplug the screen from the motherboard by lifting the wire cover and removing the screen cord.
    • Separate the hinges from the computer.
  22. HP 14-fq1025nr Keyboard Replacement: étape 22, image 1 de 1
    • Remove the screen.
  23. HP 14-fq1025nr Keyboard Replacement, Keyboard: étape 23, image 1 de 1
    • Use an iFixit opening tool to remove all the plastic hold downs from the keyboard cover.
  24. HP 14-fq1025nr Keyboard Replacement: étape 24, image 1 de 1
    • Remove all remaining plastic hold downs on the main keyboard with an iFixit opening tool.
  25. HP 14-fq1025nr Keyboard Replacement: étape 25, image 1 de 1
    • Push the keyboard out of the computer.
    • During reassembly, make sure that the keyboard is tightened properly.
Yasli Kanimba Murenzi
Membre depuis le 09/27/22
193 Réputation
2 tutoriels rédigés
Équipe
Utah Tech University, Team 1-6, McMurrin Fall 2022 Membre de l'équipe Utah Tech University, Team 1-6, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G6
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 175
