Aller au contenu principal
HP 14-fq1025nr Ports Replacement
Ce dont vous avez besoin
  1. HP 14-fq1025nr Ports Replacement, Back Cover: étape 1, image 1 de 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Ports Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Ports Replacement: étape 3, image 1 de 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Ports Replacement: étape 4, image 1 de 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Ports Replacement: étape 5, image 1 de 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Ports Replacement, Battery: étape 6, image 1 de 2 HP 14-fq1025nr Ports Replacement, Battery: étape 6, image 2 de 2
    • Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Ports Replacement: étape 7, image 1 de 1
    • Remove the battery.
  8. HP 14-fq1025nr Ports Replacement, Fan: étape 8, image 1 de 1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  9. HP 14-fq1025nr Ports Replacement: étape 9, image 1 de 1
    J'achète
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  10. HP 14-fq1025nr Ports Replacement: étape 10, image 1 de 1
    • Remove the fan.
  11. HP 14-fq1025nr Ports Replacement, Motherboard: étape 11, image 1 de 3 HP 14-fq1025nr Ports Replacement, Motherboard: étape 11, image 2 de 3 HP 14-fq1025nr Ports Replacement, Motherboard: étape 11, image 3 de 3
    • Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
  12. HP 14-fq1025nr Ports Replacement: étape 12, image 1 de 2 HP 14-fq1025nr Ports Replacement: étape 12, image 2 de 2
    J'achète
    • Unplug the wire connections.
    • Use tweezers if needed.
  13. HP 14-fq1025nr Ports Replacement: étape 13, image 1 de 1
    • Remove the motherboard.
    • Use the iFixit opening tool to pry it out if needed.
  14. HP 14-fq1025nr Ports Replacement, Ports: étape 14, image 1 de 1
Alex Cutler
Membre depuis le 09/26/22
301 Réputation
3 tutoriels rédigés
Équipe
Utah Tech University, Team 1-6, McMurrin Fall 2022 Membre de l'équipe Utah Tech University, Team 1-6, McMurrin Fall 2022
UTAHTECH-MCMURRIN-F22S1G6
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 3
Total : 93
