Aller au contenu principal
HP 15-AF131DX Optical Drive Replacement
Ce dont vous avez besoin
  1. HP 15-AF131DX Optical Drive Replacement, Optical Drive: étape 1, image 1 de 2 HP 15-AF131DX Optical Drive Replacement, Optical Drive: étape 1, image 2 de 2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  2. HP 15-AF131DX Optical Drive Replacement: étape 2, image 1 de 1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  3. HP 15-AF131DX Optical Drive Replacement: étape 3, image 1 de 3 HP 15-AF131DX Optical Drive Replacement: étape 3, image 2 de 3 HP 15-AF131DX Optical Drive Replacement: étape 3, image 3 de 3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
Aaron McCallister
Membre depuis le 09/26/17
128 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S6-G2, Banghart Fall 2017 Membre de l'équipe Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 472
