Aller au contenu principal
HP 15-AF131DX Speaker Replacement
Ce dont vous avez besoin
  1. HP 15-AF131DX Speaker Replacement, Speakers: étape 1, image 1 de 2 HP 15-AF131DX Speaker Replacement, Speakers: étape 1, image 2 de 2
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Speaker Replacement: étape 2, image 1 de 2 HP 15-AF131DX Speaker Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the speakers.
  3. HP 15-AF131DX Speaker Replacement: étape 3, image 1 de 3 HP 15-AF131DX Speaker Replacement: étape 3, image 2 de 3 HP 15-AF131DX Speaker Replacement: étape 3, image 3 de 3
    • Pull up on each individual speaker, removing the rubber holds from their plastic pins.
    • Unplug the wire that connects the speakers.
    • Carefully remove the speakers from their plastic holds.
Anthony Martinez
Membre depuis le 10/05/17
526 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team S6-G2, Banghart Fall 2017 Membre de l'équipe Cal Poly, Team S6-G2, Banghart Fall 2017
CPSU-BANGHART-F17S6G2
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 613
