Aller au contenu principal
HP 15-AF131DX Trackpad Button Circuit Board Replacement
Ce dont vous avez besoin
  1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: étape 1, image 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: étape 1, image 2 de 2
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: étape 2, image 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: étape 2, image 2 de 2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 3, image 1 de 1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 4, image 1 de 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 4, image 2 de 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 4, image 3 de 3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: étape 5, image 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: étape 5, image 2 de 2
    • Remove two rubber feet by peeling them off.
    • Remove twelve Phillips head 8.8mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 6, image 1 de 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 6, image 2 de 3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 6, image 3 de 3
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The Trackpad Button Circuit Board is found in the red box.
  7. HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 7, image 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 7, image 2 de 2
    • Remove the two 3.3mm Phillips-head screws that secure the trackpad circuit board to the top cover.
  8. HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 8, image 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Lift the plastic wire lock bracket.
    • Pull on the blue tab to remove the wire using the tweezers tool to make sure there is no damage as you pull.
  9. HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 9, image 1 de 2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 9, image 2 de 2
    • Lift the second plastic wire lock bracket.
    • Pull on the purple tab using tweezers to remove the wire.
  10. HP 15-AF131DX Trackpad Button Circuit Board Replacement: étape 10, image 1 de 1
    • Lift and remove the trackpad button circuit board.
Adrianna
Membre depuis le 11/01/18
133 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G2, Harley Fall 2018 Membre de l'équipe IUPUI, Team S2-G2, Harley Fall 2018
IUPUI-HARLEY-F18S2G2
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 358
