Introduction
The guide will detail the replacement of the back panel of the HP 15-BA078DX.
Unclip the two latches on the bottom of the laptop.
  • Unclip the two latches on the bottom of the laptop.
  • Slide the battery straight out while holding the clip open.
Ajouter un commentaire
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
  • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
  • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
  • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
  • Remember to remove the two screws under the rubber feet.
  • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
  • You may need to flip the laptop over to unlatch all of the internal clips.
  • Carefully pull the shell of the computer apart.
Benjamin DosSantos Jr
Membre depuis le 20/03/2018
367 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G4, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G4, Peak Spring 2018
UMASSD-PEAK-S18S3G4
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 18
Total : 82
