Aller au contenu principal
HP 15-BA078DX RAM Replacement
Ce dont vous avez besoin
  1. HP 15-BA078DX RAM Replacement, Battery: étape 1, image 1 de 3 HP 15-BA078DX RAM Replacement, Battery: étape 1, image 2 de 3 HP 15-BA078DX RAM Replacement, Battery: étape 1, image 3 de 3
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
  2. HP 15-BA078DX RAM Replacement, Disc Drive: étape 2, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
  3. HP 15-BA078DX RAM Replacement: étape 3, image 1 de 3 HP 15-BA078DX RAM Replacement: étape 3, image 2 de 3 HP 15-BA078DX RAM Replacement: étape 3, image 3 de 3
    • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
  4. HP 15-BA078DX RAM Replacement, Back Panel: étape 4, image 1 de 1
    • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remember to remove the two screws under the rubber feet.
  5. HP 15-BA078DX RAM Replacement: étape 5, image 1 de 3 HP 15-BA078DX RAM Replacement: étape 5, image 2 de 3 HP 15-BA078DX RAM Replacement: étape 5, image 3 de 3
    • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
    • You may need to flip the laptop over to unlatch all of the internal clips.
  6. HP 15-BA078DX RAM Replacement: étape 6, image 1 de 3 HP 15-BA078DX RAM Replacement: étape 6, image 2 de 3 HP 15-BA078DX RAM Replacement: étape 6, image 3 de 3
    • Carefully pull the shell of the computer apart.
  7. HP 15-BA078DX RAM Replacement, RAM: étape 7, image 1 de 2 HP 15-BA078DX RAM Replacement, RAM: étape 7, image 2 de 2
    • Using a plastic spudger, unclip the latch locking the RAM to the motherboard.
  8. HP 15-BA078DX RAM Replacement: étape 8, image 1 de 3 HP 15-BA078DX RAM Replacement: étape 8, image 2 de 3 HP 15-BA078DX RAM Replacement: étape 8, image 3 de 3
    • Gently tilt the RAM sticks up and slide out each stick.
Benjamin DosSantos Jr
Membre depuis le 03/20/18
469 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G4, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G4, Peak Spring 2018
UMASSD-PEAK-S18S3G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 549
