Introduction
A USB port can be diagnosed as faulty when the computer no longer detects when a device is connected via USB. Ensure the USB connections are free of debris before declaring the port as faulty.
Ce dont vous avez besoin
Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
Slide the battery out as shown in the picture.
Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
Locate the two corner grips on the hinge side of the computer.
Using a metal spudger, remove the two corner grips to reveal the screws.
Remove the 2 black screws holding the hard drive to the computer frame.
Remove the single screw holding the USB ports and chip into the computer.
