Aller au contenu principal
HP 15-ac121dx Back Panel Replacement
Ce dont vous avez besoin
  1. HP 15-ac121dx Back Panel Replacement, Battery: étape 1, image 1 de 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Back Panel Replacement: étape 2, image 1 de 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Back Panel Replacement: étape 3, image 1 de 2 HP 15-ac121dx Back Panel Replacement: étape 3, image 2 de 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Back Panel Replacement: étape 4, image 1 de 2 HP 15-ac121dx Back Panel Replacement: étape 4, image 2 de 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Back Panel Replacement, Back Panel: étape 5, image 1 de 2 HP 15-ac121dx Back Panel Replacement, Back Panel: étape 5, image 2 de 2
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. HP 15-ac121dx Back Panel Replacement: étape 6, image 1 de 1
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. HP 15-ac121dx Back Panel Replacement: étape 7, image 1 de 1
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 960
