Aller au contenu principal
HP 15-ac158dx Keyboard Replacement
Ce dont vous avez besoin
  1. HP 15-ac158dx Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac158dx Keyboard Replacement: étape 2, image 1 de 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac158dx Keyboard Replacement: étape 3, image 1 de 2 HP 15-ac158dx Keyboard Replacement: étape 3, image 2 de 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac158dx Keyboard Replacement: étape 4, image 1 de 2 HP 15-ac158dx Keyboard Replacement: étape 4, image 2 de 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac158dx Keyboard Replacement, Back Panel: étape 5, image 1 de 3 HP 15-ac158dx Keyboard Replacement, Back Panel: étape 5, image 2 de 3 HP 15-ac158dx Keyboard Replacement, Back Panel: étape 5, image 3 de 3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac158dx Keyboard Replacement: étape 6, image 1 de 1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac158dx Keyboard Replacement: étape 7, image 1 de 3 HP 15-ac158dx Keyboard Replacement: étape 7, image 2 de 3 HP 15-ac158dx Keyboard Replacement: étape 7, image 3 de 3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac158dx Keyboard Replacement, CD Compartment: étape 8, image 1 de 3 HP 15-ac158dx Keyboard Replacement, CD Compartment: étape 8, image 2 de 3 HP 15-ac158dx Keyboard Replacement, CD Compartment: étape 8, image 3 de 3
    • Locate the CD Compartment as shown and gently slide it out.
  9. HP 15-ac158dx Keyboard Replacement, Fan: étape 9, image 1 de 3 HP 15-ac158dx Keyboard Replacement, Fan: étape 9, image 2 de 3 HP 15-ac158dx Keyboard Replacement, Fan: étape 9, image 3 de 3
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  10. HP 15-ac158dx Keyboard Replacement: étape 10, image 1 de 2 HP 15-ac158dx Keyboard Replacement: étape 10, image 2 de 2
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  11. HP 15-ac158dx Keyboard Replacement: étape 11, image 1 de 2 HP 15-ac158dx Keyboard Replacement: étape 11, image 2 de 2
    • Remove fan.
    • Unscrew the two screws holding in the fan.
  12. HP 15-ac158dx Keyboard Replacement, Motherboard: étape 12, image 1 de 1
    • Remove the TEN 3mm screws.
    • Remove the ONE 9mm screw.
  13. HP 15-ac158dx Keyboard Replacement: étape 13, image 1 de 2 HP 15-ac158dx Keyboard Replacement: étape 13, image 2 de 2
    • Locate the four ribbon clips.
    • Lift the grey part of the ribbon clips.
    • Pull the ribbon cable out and repeat this step for all four ribbon cables.
    • Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
  14. HP 15-ac158dx Keyboard Replacement: étape 14, image 1 de 2 HP 15-ac158dx Keyboard Replacement: étape 14, image 2 de 2
    • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
  15. HP 15-ac158dx Keyboard Replacement: étape 15, image 1 de 1
    • Remove the motherboard.
  16. HP 15-ac158dx Keyboard Replacement, Keyboard: étape 16, image 1 de 2 HP 15-ac158dx Keyboard Replacement, Keyboard: étape 16, image 2 de 2
    • Remove the Hard Drive.
  17. HP 15-ac158dx Keyboard Replacement: étape 17, image 1 de 2 HP 15-ac158dx Keyboard Replacement: étape 17, image 2 de 2
    • Lift up the cable port and place it to the side but do not remove completely from the laptop.
    • Remove the single Phillips screw securing it first.
  18. HP 15-ac158dx Keyboard Replacement: étape 18, image 1 de 3 HP 15-ac158dx Keyboard Replacement: étape 18, image 2 de 3 HP 15-ac158dx Keyboard Replacement: étape 18, image 3 de 3
    • Remove the VENDOR component.
    • Unscrew the single Phillips screw holding it to the frame first.
  19. HP 15-ac158dx Keyboard Replacement: étape 19, image 1 de 2 HP 15-ac158dx Keyboard Replacement: étape 19, image 2 de 2
    • Using a plastic prying tools, remove the grey metal plate.
    • It will not come off easy, but do not force it off.
  20. HP 15-ac158dx Keyboard Replacement: étape 20, image 1 de 3 HP 15-ac158dx Keyboard Replacement: étape 20, image 2 de 3 HP 15-ac158dx Keyboard Replacement: étape 20, image 3 de 3
    • Locate the damaged keyboard and lift up with the prying tool to remove.
    • To put everything back together and use your laptop with the new keyboard, follow the steps in REVERSE..
    • ENJOY :)
5 autres ont terminé cette réparation.
Onose Aigbe
Membre depuis le 01/30/18
390 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S1-G2, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 membres
6 tutoriels rédigés
2 commentaires
Did you have to use soldering iron to melt the plastic rivets when putting back the keyboard?
Cheers.
Lo Yuk Fai - Réponse
I have done these before and yes, using a soldering iron to melt the plastic rivets is a good method.
Richard Ness -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 23
30 derniers jours : 134
Total : 5,190
