Aller au contenu principal
HP 15-ac121dx Screen Replacement
Ce dont vous avez besoin
  1. HP 15-ac121dx Screen  Replacement, Battery: étape 1, image 1 de 1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Screen  Replacement: étape 2, image 1 de 1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Screen  Replacement: étape 3, image 1 de 2 HP 15-ac121dx Screen  Replacement: étape 3, image 2 de 2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Screen  Replacement: étape 4, image 1 de 2 HP 15-ac121dx Screen  Replacement: étape 4, image 2 de 2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Screen  Replacement, Screen: étape 5, image 1 de 1
    • Open the laptop so that the screen is facing you.
  6. HP 15-ac121dx Screen  Replacement: étape 6, image 1 de 2 HP 15-ac121dx Screen  Replacement: étape 6, image 2 de 2
    • With the screen facing you, use the plastic opening tool to remove the liner around the screen
  7. HP 15-ac121dx Screen  Replacement: étape 7, image 1 de 1
    • Using a Phillips #000 screwdriver, remove all four 2mm screws in each corner of the screen.
  8. HP 15-ac121dx Screen  Replacement: étape 8, image 1 de 2 HP 15-ac121dx Screen  Replacement: étape 8, image 2 de 2
    • Carefully remove the screen and place it face down on the keyboard.
    • Do not pull the screen away from the front panel assembly, as this would damage the cord connecting the screen to the front panel assembly.
  9. HP 15-ac121dx Screen  Replacement: étape 9, image 1 de 2 HP 15-ac121dx Screen  Replacement: étape 9, image 2 de 2
    • With the screen faced down on the keyboard, remove the grounding tape adhered to the back of the screen.
    • You should see a 36-pin plug underneath the grounding tape.
    • Carefully remove the 36-pin plug, not to damage the grounding tape or the plug.
Keefe White
Membre depuis le 09/30/19
121 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 773
