Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This Guide will walk you through replacing your keyboard on a HP 15-ac158dx Laptop. This is not an easy process, so you will want to pull out your plastic prying tools and Philips J00 Screw Driver and follow the instructions closely.
  1. Remove all external devices from the computer.
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. Turn off the computer by holding the power button.
    • Turn off the computer by holding the power button.
  3. To remove the battery, slide the left slider on the back to the unlocked position. To remove the battery, slide the left slider on the back to the unlocked position.
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. Push the right slider inwards. Remove the battery out by pulling straight out and to the right.
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. Locate the CD Compartment panel and gently slide it out. Locate the CD Compartment panel and gently slide it out. Locate the CD Compartment panel and gently slide it out.
    • Locate the CD Compartment panel and gently slide it out.
  6. Remove the back of the laptop by unscrewing the screws shown.
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off. Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed! Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. Locate the CD Compartment as shown and gently slide it out. Locate the CD Compartment as shown and gently slide it out. Locate the CD Compartment as shown and gently slide it out.
    • Locate the CD Compartment as shown and gently slide it out.
  9. Locate the Fan as shown. Pull out the black cable, with four wires attached from its port. Pull out the black cable, with four wires attached from its port.
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  10. Pull out the white cable wire from its port. Unscrew the two black Phillips screws holding in the fan.
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  11. Remove fan. Unscrew the two screws holding in the fan.
    • Remove fan.
    • Unscrew the two screws holding in the fan.
  12. Remove the TEN 3mm screws.
    • Remove the TEN 3mm screws.
    • Remove the ONE 9mm screw.
  13. Locate the four ribbon clips. Lift the grey part of the ribbon clips.
    • Locate the four ribbon clips.
    • Lift the grey part of the ribbon clips.
    • Pull the ribbon cable out and repeat this step for all four ribbon cables.
    • Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
  14. Pull out the white cable (contains red and white cable attached to a black support) with wires from its port. Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
    • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
  15. Remove the motherboard.
    • Remove the motherboard.
  16. Remove the Hard Drive. Remove the Hard Drive.
    • Remove the Hard Drive.
  17. Lift up the cable port and place it to the side but do not remove completely from the laptop. Remove the single Phillips screw securing it first.
    • Lift up the cable port and place it to the side but do not remove completely from the laptop.
    • Remove the single Phillips screw securing it first.
  18. Remove the VENDOR component. Unscrew the single Phillips screw holding it to the frame first. Unscrew the single Phillips screw holding it to the frame first.
    • Remove the VENDOR component.
    • Unscrew the single Phillips screw holding it to the frame first.
  19. Using a plastic prying tools, remove the grey metal plate. It will not come off easy, but do not force it off.
    • Using a plastic prying tools, remove the grey metal plate.
    • It will not come off easy, but do not force it off.
  20. Locate the damaged keyboard and lift up with the prying tool to remove. Locate the damaged keyboard and lift up with the prying tool to remove. Locate the damaged keyboard and lift up with the prying tool to remove.
    • Locate the damaged keyboard and lift up with the prying tool to remove.
    • To put everything back together and use your laptop with the new keyboard, follow the steps in REVERSE..
    • ENJOY :)
4 autre(s) ont terminé cette réparation.
Onose Aigbe
Membre depuis le 30/01/2018
390 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S1-G2, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G2, Johnson Spring 2018
BU-JOHNSON-S18S1G2
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 44
30 derniers jours : 115
Total : 3,009
