Aller au contenu principal
HP 15-af123cl Hard Drive Replacement
Ce dont vous avez besoin
  1. HP 15-af123cl Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP 15-af123cl Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Push the slider with a lock symbol to the right to unlock the battery.
  2. HP 15-af123cl Hard Drive Replacement: étape 2, image 1 de 1
    • Push the slider with a battery symbol to the left to push the battery out slightly.
    • Pull the battery out fully now that it is released.
  3. HP 15-af123cl Hard Drive Replacement, Back Cover: étape 3, image 1 de 1
    • Remove the twelve screws from the bottom of the laptop using a Phillips #00 screwdriver.
  4. HP 15-af123cl Hard Drive Replacement: étape 4, image 1 de 3 HP 15-af123cl Hard Drive Replacement: étape 4, image 2 de 3 HP 15-af123cl Hard Drive Replacement: étape 4, image 3 de 3
    • Turn the laptop over and open the lid.
    • Use an opening tool to pry the bottom cover from the body of the laptop.
  5. HP 15-af123cl Hard Drive Replacement: étape 5, image 1 de 2 HP 15-af123cl Hard Drive Replacement: étape 5, image 2 de 2
    • Close and turn over the laptop again.
    • Pull the back cover up to remove it from the laptop.
  6. HP 15-af123cl Hard Drive Replacement, Hard Drive: étape 6, image 1 de 2 HP 15-af123cl Hard Drive Replacement, Hard Drive: étape 6, image 2 de 2
    • Unclip the cable connected to the drive using an opening tool.
  7. HP 15-af123cl Hard Drive Replacement: étape 7, image 1 de 3 HP 15-af123cl Hard Drive Replacement: étape 7, image 2 de 3 HP 15-af123cl Hard Drive Replacement: étape 7, image 3 de 3
    • Remove the screws from the brackets around the hard drive using a Phillips #00 screwdriver.
  8. HP 15-af123cl Hard Drive Replacement: étape 8, image 1 de 1
    • Remove the brackets from around the hard drive.
    • Remove the hard drive from the laptop.
Victoria Santos
Membre depuis le 10/25/21
698 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-5, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 2-5, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 426
