Aller au contenu principal
HP 15-ay014dx Hard Drive Disk Replacement
Ce dont vous avez besoin
  1. HP 15-ay014dx Hard Drive Disk Replacement, Battery: étape 1, image 1 de 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Hard Drive Disk Replacement: étape 2, image 1 de 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Hard Drive Disk Replacement: étape 3, image 1 de 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Hard Drive Disk Replacement, Optical Drive: étape 4, image 1 de 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Hard Drive Disk Replacement: étape 5, image 1 de 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: étape 6, image 1 de 2 HP 15-ay014dx Hard Drive Disk Replacement, Hard Drive Disk: étape 6, image 2 de 2
    • Remove the highlighted screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Hard Drive Disk Replacement: étape 7, image 1 de 3 HP 15-ay014dx Hard Drive Disk Replacement: étape 7, image 2 de 3 HP 15-ay014dx Hard Drive Disk Replacement: étape 7, image 3 de 3
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
    • Pull the back cover off.
  8. HP 15-ay014dx Hard Drive Disk Replacement: étape 8, image 1 de 3 HP 15-ay014dx Hard Drive Disk Replacement: étape 8, image 2 de 3 HP 15-ay014dx Hard Drive Disk Replacement: étape 8, image 3 de 3
    • Pry up on the clamp holding the SATA power ribbon using the plastic opening tool.
    • Pull out the SATA power ribbon using the tweezers.
  9. HP 15-ay014dx Hard Drive Disk Replacement: étape 9, image 1 de 2 HP 15-ay014dx Hard Drive Disk Replacement: étape 9, image 2 de 2
    • Remove the highlighted screws holding the hard drive to the body using the Philips #00 screwdriver.
    • Remove the hard drive.
  10. HP 15-ay014dx Hard Drive Disk Replacement: étape 10, image 1 de 1
    • Remove the 4 screws holding the hard drive to the hard drive cage using the Philips #00 screwdriver.
6 autres ont terminé cette réparation.
Jimmy Huynh
Membre depuis le 09/26/17
263 Réputation
1 tutoriel rédigé
Équipe
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S1-G4, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G4
6 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 10
Total : 1,926
