Aller au contenu principal
HP 15-ay014dx Heat sink Replacement
Ce dont vous avez besoin
  1. HP 15-ay014dx Heat sink Replacement, Battery: étape 1, image 1 de 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Heat sink Replacement: étape 2, image 1 de 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Heat sink Replacement: étape 3, image 1 de 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Heat sink Replacement, Optical Drive: étape 4, image 1 de 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Heat sink Replacement: étape 5, image 1 de 1
    • Grip the optical drive and gently pull it out.
  6. HP 15-ay014dx Heat sink Replacement, Wireless Card: étape 6, image 1 de 1
    • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  7. HP 15-ay014dx Heat sink Replacement: étape 7, image 1 de 2 HP 15-ay014dx Heat sink Replacement: étape 7, image 2 de 2
    • Using the spudger, push in the tabs in the back that hold the body together. Carefully pry the body apart by working the spudger around the body.
  8. HP 15-ay014dx Heat sink Replacement: étape 8, image 1 de 2 HP 15-ay014dx Heat sink Replacement: étape 8, image 2 de 2
    • Using the spudger, carefully pry the wire connecting the wireless card to the motherboard off of it.
  9. HP 15-ay014dx Heat sink Replacement: étape 9, image 1 de 1
    • Using the size #00 Phillips screwdriver remove the single screw holding it in place.
  10. HP 15-ay014dx Heat sink Replacement: étape 10, image 1 de 1
    • carefully pull the card of its slot.
  11. HP 15-ay014dx Heat sink Replacement, Heat sink: étape 11, image 1 de 1
    • Remove the four screws holding the heatsink on.
  12. HP 15-ay014dx Heat sink Replacement: étape 12, image 1 de 1
    • Carefully pry the heat sink up and out of position to un-stick it from the thermal paste.
    • When reassembling, follow these steps on Comment appliquer de la pâte thermique underneath the heatsink.
Drake Scoville
Membre depuis le 09/21/17
533 Réputation
4 tutoriels rédigés
Équipe
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S1-G4, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G4
6 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 402
