Aller au contenu principal
HP 15-ay014dx Optical Drive Replacement
Ce dont vous avez besoin
  1. HP 15-ay014dx Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Disconnect device from power source and power down.
  2. HP 15-ay014dx Optical Drive Replacement: étape 2, image 1 de 1
    • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  3. HP 15-ay014dx Optical Drive Replacement: étape 3, image 1 de 1
    • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
    • Gently grasp the battery and pull it back away from the device and yourself.
  4. HP 15-ay014dx Optical Drive Replacement, Optical Drive: étape 4, image 1 de 1
    • Close the laptop and lay it down with the bottom facing up.
    • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  5. HP 15-ay014dx Optical Drive Replacement: étape 5, image 1 de 1
    • Grip the optical drive and gently pull it out.
2 autres ont terminé cette réparation.
Colton King
Membre depuis le 09/21/17
227 Réputation
1 tutoriel rédigé
Équipe
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S1-G4, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G4
6 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 2
Total : 277
