Introduction
This guide will show you how to safely remove the RAM in your HP 15-ay014dx laptop for replacement.
Disconnect device from power source and power down.
  • Disconnect device from power source and power down.
Ajouter un commentaire
With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  • With the device turned upside down, use your index fingers to push the battery latches in towards each other.
  • The latch on your left will stay at the inward position, while the latch on the right will slide back out.
  • Gently grasp the battery and pull it back away from the device and yourself.
  • Close the laptop and lay it down with the bottom facing up.
  • Using a size #00 Phillips screw drive remove the screw holding in the optical drive.
  • Grip the optical drive and gently pull it out.
  • Remove the 11 screws holding the body of the laptop together with a size #00 Phillips screwdriver.
  • Use the spudger to press the tabs in the back of the computer. Carefully remove the back of the laptop by prying around the sides using the plastic opening tool.
  • Undo the clips holding the RAM in place using the plastic opening tool.
  • Carefully pull out the RAM from the motherboard.
Drake Scoville
Membre depuis le 21/09/2017
419 Réputation
4 tutoriels rédigés
Équipe
Washington State, Team S1-G4, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S1-G4, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G4
6 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 122
