Aller au contenu principal
HP 15-ay103dx Motherboard Replacement
Ce dont vous avez besoin
  1. HP 15-ay103dx Motherboard  Replacement, Battery: étape 1, image 1 de 1
    • Slide the two battery lock latches on the back of the device to the “unlock” position.
  2. HP 15-ay103dx Motherboard  Replacement: étape 2, image 1 de 1
    • Lift the battery upward to remove it from the device.
  3. HP 15-ay103dx Motherboard  Replacement, Back Panel: étape 3, image 1 de 1
    • Using the PH1 phillips-head screwdriver, remove all the 5/16 in. screws from the back of the device.
    • There should be 10 in total, be sure to keep them together!
  4. HP 15-ay103dx Motherboard  Replacement: étape 4, image 1 de 1
    • Locate the optical disc drive and remove it from the device by sliding it straight of the device.
  5. HP 15-ay103dx Motherboard  Replacement: étape 5, image 1 de 2 HP 15-ay103dx Motherboard  Replacement: étape 5, image 2 de 2
    • Covering the hinges of the device are rubber bumpers secured to the device using adhesive. Remove them carefully.
    • Place the adhesive side up as you will need to place them back after your replacement is complete.
  6. HP 15-ay103dx Motherboard  Replacement: étape 6, image 1 de 2 HP 15-ay103dx Motherboard  Replacement: étape 6, image 2 de 2
    • In the same spot you’ve just removed the bumpers from, you will find two 5/16 in. screws. Using the same Phillips-head screwdriver used in step 2, remove the screws
    • Be sure to keep the screws together!
  7. HP 15-ay103dx Motherboard  Replacement: étape 7, image 1 de 1
    • Carefully remove the back panel from the device.
    • If you are unable to do this with your hands, you can use a thin prying tool of your choice to make it easier!
  8. HP 15-ay103dx Motherboard  Replacement, Motherboard: étape 8, image 1 de 3 HP 15-ay103dx Motherboard  Replacement, Motherboard: étape 8, image 2 de 3 HP 15-ay103dx Motherboard  Replacement, Motherboard: étape 8, image 3 de 3
    • Disconnect the wires around the motherboard securing it to the device.
    • To do this, flip the black "switches" securing the wires into place upwards.
  9. HP 15-ay103dx Motherboard  Replacement: étape 9, image 1 de 1
    • Remove the six 5/16 in. screws holding the motherboard onto the device using the P1 philips-head screwdriver.
    • Be sure to keep them together!
  10. HP 15-ay103dx Motherboard  Replacement: étape 10, image 1 de 3 HP 15-ay103dx Motherboard  Replacement: étape 10, image 2 de 3 HP 15-ay103dx Motherboard  Replacement: étape 10, image 3 de 3
    • Disconnect the wire securing the whole motherboard located at the top to the motherboard.
    • This is possible with your fingers, but is easier to do using an iFixit opening tool.
  11. HP 15-ay103dx Motherboard  Replacement: étape 11, image 1 de 1
    • Carefully lift the motherboard to remove it from the device.
Rafael Cardona Bautista
Membre depuis le 09/25/17
104 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 8
Total : 1,572
