Introduction
Follow this guide to replace the hard drive on HP 15-ba0709dx laptop. This repair may be needed if your computer is showing the symptoms such as freezing, slowing down, or corrupting files.
Outils
Pièces
Aucune pièce spécifiée.
Flip the device over and locate the battery compartment.
Slide the battery release latch on the left and right side until the battery is detached from its slot.
A noticeable pop will be heard when the battery is fully released.
Place the laptop on a clean, flat surface with the bottom side facing up.
Locate the square, blue hard drive
Unscrew the two screws holding it in place using a Philips screwdriver head, PH1. The screws will be 8 mm long with a 4 mm width head.
5 autres ont terminé cette réparation.
