Aller au contenu principal
HP 15-bw0xx Battery Replacement
Ce dont vous avez besoin
  1. HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: étape 1, image 1 de 3 HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: étape 1, image 2 de 3 HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: étape 1, image 3 de 3
    • First, start by identifying your laptop. Be sure it is specifically the "HP Laptop 15-bw0xx" model.
    • If you are unsure of the model, turn on your laptop. Then press and hold the "FN" key and the "ESC" key at the same time.
    • The model type is under the title "Product name."
  2. HP 15-bw0xx Battery Replacement: étape 2, image 1 de 1
    • Turn the closed laptop over onto its face, with the hinged side facing away from you.
    • Be sure to unplug your laptop and turn it off before continuing.
  3. HP 15-bw0xx Battery Replacement: étape 3, image 1 de 3 HP 15-bw0xx Battery Replacement: étape 3, image 2 de 3 HP 15-bw0xx Battery Replacement: étape 3, image 3 de 3
    • Place a finger on the top left slider, then push the black piece all the way to the right.
    • A finger grip to slide the hinge lock open lies to the left of a closed padlock symbol. This is how the battery is unlocked or locked in place.
  4. HP 15-bw0xx Battery Replacement: étape 4, image 1 de 3 HP 15-bw0xx Battery Replacement: étape 4, image 2 de 3 HP 15-bw0xx Battery Replacement: étape 4, image 3 de 3
    • Place a finger on the top right slider, then slide the black piece all the way to the left until it clicks out of place.
    • There will be three vertically parallel finger grips on the slider and a small 3/4 full battery symbol to the left of the slider. This slider is what detaches the battery from the laptop.
    • You may need to use a thumb or a little force to complete this step.
  5. HP 15-bw0xx Battery Replacement: étape 5, image 1 de 1
    • Remove the battery from the laptop.
  6. HP 15-bw0xx Battery Replacement: étape 6, image 1 de 3 HP 15-bw0xx Battery Replacement: étape 6, image 2 de 3 HP 15-bw0xx Battery Replacement: étape 6, image 3 de 3
    • Gently line the new battery up to the slot in which you removed the old battery from.
    • Press the battery into the slot until you hear it click into place.
  7. HP 15-bw0xx Battery Replacement: étape 7, image 1 de 3 HP 15-bw0xx Battery Replacement: étape 7, image 2 de 3 HP 15-bw0xx Battery Replacement: étape 7, image 3 de 3
    • Reverse Step #4 in order to safely lock the battery in place.
After completing all of these steps, you will have successfully replaced your HP Laptop 15-bw0xx battery.
3 autres ont terminé cette réparation.
Imani Kimbrough
Membre depuis le 09/14/20
199 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
hello, any idea where I can get a genuine battery for this laptop?
Brian Mwangi - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 10
30 derniers jours : 55
Total : 3,114
