Aller au contenu principal
HP 15-da0002dx SSD Replacement
Ce dont vous avez besoin
  1. HP 15-da0002dx SSD Replacement, Back Cover: étape 1, image 1 de 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx SSD Replacement: étape 2, image 1 de 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx SSD Replacement: étape 3, image 1 de 2 HP 15-da0002dx SSD Replacement: étape 3, image 2 de 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx SSD Replacement: étape 4, image 1 de 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx SSD Replacement: étape 5, image 1 de 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx SSD Replacement: étape 6, image 1 de 2 HP 15-da0002dx SSD Replacement: étape 6, image 2 de 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx SSD Replacement: étape 7, image 1 de 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx SSD Replacement, Battery: étape 8, image 1 de 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx SSD Replacement: étape 9, image 1 de 2 HP 15-da0002dx SSD Replacement: étape 9, image 2 de 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
  10. HP 15-da0002dx SSD Replacement, SSD: étape 10, image 1 de 1
    • Remove the screw holding the SSD in place using the Phillips #1 screwdriver.
  11. HP 15-da0002dx SSD Replacement: étape 11, image 1 de 1
    • Carefully pull the SSD away from the socket.
2 autres ont terminé cette réparation.
Abigail Aron
Membre depuis le 09/04/19
941 Réputation
5 tutoriels rédigés
Équipe
Un commentaire
sir
can we add a hdd of 1tb also without replacing ssd???
Kranti Ajit - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 23
Total : 2,066
