Aller au contenu principal
HP 15-da0012dx Fan Replacement
Ce dont vous avez besoin
  1. HP 15-da0012dx Fan Replacement, Battery: étape 1, image 1 de 2 HP 15-da0012dx Fan Replacement, Battery: étape 1, image 2 de 2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx Fan Replacement: étape 2, image 1 de 3 HP 15-da0012dx Fan Replacement: étape 2, image 2 de 3 HP 15-da0012dx Fan Replacement: étape 2, image 3 de 3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx Fan Replacement: étape 3, image 1 de 2 HP 15-da0012dx Fan Replacement: étape 3, image 2 de 2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx Fan Replacement: étape 4, image 1 de 2 HP 15-da0012dx Fan Replacement: étape 4, image 2 de 2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx Fan Replacement: étape 5, image 1 de 3 HP 15-da0012dx Fan Replacement: étape 5, image 2 de 3 HP 15-da0012dx Fan Replacement: étape 5, image 3 de 3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx Fan Replacement: étape 6, image 1 de 2 HP 15-da0012dx Fan Replacement: étape 6, image 2 de 2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx Fan Replacement: étape 7, image 1 de 2 HP 15-da0012dx Fan Replacement: étape 7, image 2 de 2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx Fan Replacement, Fan: étape 8, image 1 de 2 HP 15-da0012dx Fan Replacement, Fan: étape 8, image 2 de 2
    • Using the Phillips #1 screwdriver, remove the single 6.0 mm screw holding the fan in place.
  9. HP 15-da0012dx Fan Replacement: étape 9, image 1 de 1
    • Using the tip of the blue plastic opening tool or your fingernail, pull the connector for the fan cable straight out of the socket.
    • To reinstall the cable, push the connector straight into the socket.
  10. HP 15-da0012dx Fan Replacement: étape 10, image 1 de 2 HP 15-da0012dx Fan Replacement: étape 10, image 2 de 2
    • Lift the fan from the computer.
Xavier Hung
Membre depuis le 02/07/19
914 Réputation
4 tutoriels rédigés
Équipe
UC Davis, Team S20-G4, Lore Winter 2019 Membre de l'équipe UC Davis, Team S20-G4, Lore Winter 2019
UCD-LORE-W19S20G4
3 membres
7 tutoriels rédigés
Un commentaire
In Step 9, the instructions are not clear "Using the tip of the blue plastic opening tool or your fingernail, pull the connector for the fan cable straight out of the socket.". By straight out, that could mean straight up. However, the connector needs to be pulled straight back towards the fan body. It is difficult to see which way the connector should go. Otherwise, the instructions are excellent.
Robert Sharer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 22
Total : 1,759
